Old 02-08-2010, 07:40 PM   #1
grayjrms
need help on 4x4 1 ton
i have a 1982 1 ton dually that the front axle is bad will a 3/4 ton axle work and still use the dually rims. thanks bigjim
grayjrms is offline   Reply With Quote
Old 02-08-2010, 10:17 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: need help on 4x4 1 ton
Lets see if someone here can help you..
tvblazer78 is offline   Reply With Quote
Old 02-08-2010, 11:04 PM   #3
80SPORT
80SPORT's Avatar
Your 1 ton front axle is a dana 60;the 3/4 ton uses a gm 10 bolt corporate;you rims will not work but you could use std 3/4 ton rims of the same size;the most important issue would be to match gear ratio.
Unless your dana 60 dually housing is damaged I would repair your original;dana parts are readily available new or used ....
80SPORT is offline   Reply With Quote
Old 02-09-2010, 09:21 AM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
80SPORT is right, but...is your truck a DRW or SRW? If its DRW then you need DRW front hubs. If its SRW then a 3/4 will work. Make sure you have the ratio the same or you will kill your transfer case. Also, if you plan on doing hauling and such with the 3/4t in it, make sure it isnt a D44HD or a 10BHD. Make sure its a D60.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
