05-25-2002, 06:44 AM | #1 |
Disc Brakes...
I was wondering if the whole dis brake assembly (Master Cylinder, Power Booster, Proportining Valve and lines) from a 78 truck can be fitted onto a 68 truck? What would be necesarry for this modification?
05-25-2002, 07:22 AM | #2 |
The direct answer to your question is YES!!
The only modification that is necessary is that if you transfer the entire front end assembly eg: cross member and all... there might be a couple of large attachment bolt holes to re-drill. I have done this and it works quite well. The holes will be very appearant once you get the disc brake front end in place. ------------------ 1972 GMC Jimmy (topless reigns) 1996 ImpalaSS 1994 ImpalaSS too many toys!!!
1972 GMC Jimmy (topless reigns) 1996 ImpalaSS 1994 ImpalaSS too many toys!!! |
05-25-2002, 09:49 AM | #3 |
I have 75 parts on the longhorn,but didnt change the crossmember. all of the lines,hoses ,prop valve,master & booster can be fitted. I have a manual disc(vacumn issues with a very health cam that was in a BB Olds at the time),so I cant really say on mods for the booster. the manual brake master bolted right on,with an adjustment to the brake rod. I drilled a hole in the frame(1 ea side) for the brake hoses,& mounted the prop valve to the front crossmember(had to drill holes for that also. the brake hoses are also bolted to the front of the upper a arm( this required a slot on the of the a arm to mount). Good luck........69longhorn
http://community.webshots.com/user/hotrodhorn |
05-25-2002, 10:47 AM | #4 |
I have 73-up spindles on my truck. So you should be able to transfer everything over without changing your crossmember.
------------------ '69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front & rear sway bars See my truck at: http://www.geocities.com/low69cst/ Student at the University of Kentucky. Feel free to message me on AOL, SN- SS95ZQ8 Lexington, Kentucky
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
05-25-2002, 08:47 PM | #5 |
Assuming you have a C10 2WD, you can keep your crossmember, crosslink, inner tie rod ends, idler arm, and Pittman arm, but will need to use 73-87 outer tie rod ends (Moog ES409RT). They are the same length as yours and will screw right on to your tie rod adjuster sleeves. You will also need 73-87 upper ball joints (Moog K6136). The lowers are the same for 71-87 C10 2WD trucks.
------------------ MikeB 69 C-10 Fleetside, mild 383, Dart Iron Eagle heads, Crane Energizer 266 cam and 1.6 roller rockers, Edelbrock Performer manifold and 600cfm carb, HEI w/ MSD components, 1986 front spindles/disc brakes, Vintage Air in-dash.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
05-28-2002, 08:41 PM | #6 |
Boosted Member
I found a nice '86 C-10 in the junkyard. Can I swap those upper and lower control arms right over to the '67 crossmember in my truck? Cuz that'd be pretty sweet.
Thanks,
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
