Old 02-13-2010, 05:01 PM   #1
texanidiot25
Eat My Rust
texanidiot25's Avatar
Pan Hard bar problem after axle swap
The large stud that comes off the axle housing on the new GM 12bolt is shorter than the one from the Dana 60 that just came off. The bar is lined up too far towards the rear of the truck to bolt up to the GM 12 bolt. What gives? Is there a different legth stud that can be found? Can't swap the studs between the axles, since the Dana's is thicker...
texanidiot25 is offline   Reply With Quote
Old 02-13-2010, 08:31 PM   #2
texanidiot25
Eat My Rust
Re: Pan Hard bar problem after axle swap
ttt, really need some info on this.
Old 02-13-2010, 08:50 PM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
looks like you have a pretty good drop....why not make up a new bar and run it to the back of the trailing arm...?
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 02-13-2010, 08:54 PM   #4
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Talking Re: Pan Hard bar problem after axle swap
Check out this site http://www.classicperform.com/NewPro...ionPackage.htm They have about every style of bar you can imagine.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 02-13-2010, 11:52 PM   #5
texanidiot25
Eat My Rust
Unfortunatly I don't have the time or money at the moment to get aftermarket stuff, nor the tools to build. Need to have it going ideally by monday..
What I'm asking is why don't factory parts bolt up? There's no way any bar will work (that's not kinked, and every aftermarket one I've seen in person is straight) since the bracket and rear end doesn't line up... The Dana had the panhard spaced further away from the axle and had no problem lining up, but the 12 bolt's panhard stud doesn't come out far enough..
Old 02-14-2010, 12:15 AM   #6
Firefighter
http://www.classicperform.com/Store/...ck/CP32021.htm Not even this bar? It is bent to clear the diff cover and they also have new studs available.
Yellville, Ar. USA
Old 02-14-2010, 12:18 AM   #7
dfwright
dfwright's Avatar
Does the bracket need to be moved?
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 02-14-2010, 12:22 AM   #8
texanidiot25
Eat My Rust
Well that's all I need is that stud, a longer one like the Dana had and there's no problem. Even at this 3" drop, the pan hard is only off center by a 1/4 of an inch, and it's near level at ride height.
Are there different length studs from the factory? There's a junkyard near here with a few of these trucks, but curious if it's worth driving out.
RTAS Rear End Track Arm Mount Stud, ea $19.00
http://www.classicperform.com/6092chevtrk.htm#44
Is this it?
DFWRIGHT- It's an option, just don't have the tools where the truck is at to chisel off the rivets and drill holes. Unless there's other holes in the frame? If I could move the whole bracket forward an inch or so, or rotate it..
Old 02-14-2010, 12:58 AM   #9
Firefighter
Yes I believe the RTAS is the one you need to get this fixed. I don't know if there are different studs that came out from the factory or not though. Hopefully you can get it fixed!!
Yellville, Ar. USA
Old 02-14-2010, 11:13 AM   #10
OhOneWS6
OhOneWS6's Avatar
Maybe a pic would hep. Someone might see something you are missing.
OhOneWS6 is offline   Reply With Quote
Old 02-15-2010, 10:14 AM   #11
71Bowties
71Bowties's Avatar
Subscribed.
I want to keep an eye on this thread cause I am swapping over to a coil spring rear suspension with a D60 rearend. I am wondering if it the coil spring suspension with the D60 actually mounts the panyard bar back farther on the frame due to the fact that the stud is longer to clear the bigger dif cover?
71 GMC C15 swb
71 K5 Blazer
72 K10 Woodhauler
89 Suburban
13 Duramax
71Bowties is offline   Reply With Quote
Old 02-15-2010, 11:43 AM   #12
Willys47
Willys47's Avatar
that stud is longer to keep the panhard bar fron hitting the dif cover.On the Eaton ho52? the bar was longer and a bracket was welded to the axle tube and not to the center housing as in the 12 bolt and I guess the Dana 60.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 02-18-2010, 10:01 AM   #13
71Bowties
71Bowties's Avatar
Just fyi, here is a picture of a D60 with a stock panyard bar in it for reference.
71 GMC C15 swb
71 K5 Blazer
72 K10 Woodhauler
89 Suburban
13 Duramax
