Old 02-15-2010, 09:23 PM   #1
63 & 64 Bowties
and a few others
S-10 swappers: how did you mount your running boards?
I was starting to remove my running board brackets, but I wonder if I can even use them. How did everyone mount the running boards to the S-10 frame?
thanks
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 02-15-2010, 10:48 PM   #2
britnjc
britnjc's Avatar
Re: S-10 swappers: how did you mount your running boards?
Mine was in the ad kit that i bought, you can go to their websit and get an idea on the design. But if I was making my own I would just get some 1x2 tubing welded to flat stock with bracing and bolt the to the frame. Just my opinion, hopefully others will chime in own their home made versions.
britnjc is offline   Reply With Quote
Old 02-15-2010, 11:25 PM   #3
BlueJeep
BlueJeep's Avatar
I cut mine down and welded them right to the s10 frame.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 02-16-2010, 10:16 AM   #4
ClassicDreamer
had mine fabbed to spec with flat stock
ClassicDreamer is offline   Reply With Quote
Old 02-16-2010, 10:38 AM   #5
Dan Bowles
AD Addict
I had someone who bought a kit that didn't use it show me theirs. So I did just what britnjc calls for, 1 x 2 tube stock with flat stock with bolt holes and gussets.
Dan Bowles is offline   Reply With Quote
Old 02-16-2010, 10:43 AM   #6
1952ssr
1952ssr's Avatar
Here is a picture on mine. I will take some closer ones for you tonight. Some I cut down and welded right to the frame others I made a flat piece to replace the cut off base to get a better welding area, though I don't think it really matters.
1952ssr is offline   Reply With Quote
Old 02-16-2010, 11:20 AM   #7
texas56
texas56's Avatar
We cut ours down and welded them to the stock frame. Had to shorten a couple and notch that front one around bodymount. This is only pic I have here with me today but will try and remember to get you more. This was VERY tricky to get all the sheetmetal gaps and aligned when we mocked it up. Took several trys.
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline   Reply With Quote
Old 02-16-2010, 01:05 PM   #8
63 & 64 Bowties
and a few others
Thanks guys. I guess I better try to salvage those original brackets. It's just that the frame rivets are a major pain. My buddy has a plasma cutter, maybe I'll hit him up to borrow it.
Old 02-16-2010, 01:42 PM   #9
BlueJeep
BlueJeep's Avatar
I blew the rivet heads off with a torch and popped the brackets with a 2 lb hammer and they fell right off, easy.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-16-2010, 02:11 PM   #10
63 & 64 Bowties
and a few others
Thanks, I'll try that. I was thinking of the smoke wrench, but first I tried an air chisel, then the wiz wheel. I got two rivets off from the inside that way then punched them out, but whew, that was hard.
Old 02-16-2010, 05:45 PM   #11
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
When removing a bunch of rivets I've found variety in approach makes it less tedious. I'll chisel the heads off the easy ones, grind some and drill others. Then I'll drive them out the rivet with a long punch.
I don't like using a torch because I almost always end up cutting something I didn't intend to.
Steve@OldSub.com is offline   Reply With Quote
Old 02-16-2010, 06:30 PM   #12
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
That's what I did also. Check out jeffs51chevy build page also. He had a great idea for mounting his. It should be in the first page or two.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 02-16-2010, 08:03 PM   #13
mylow53
mylow53's Avatar
i heard you grind off the top and punch out the rivit...
Good luck
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 02-16-2010, 09:27 PM   #14
chevy49
chevy49's Avatar
with a plasma cutter it is fast cut off heads on the inside and drive out the rivets with punch.
chevy49 is offline   Reply With Quote
Old 02-16-2010, 11:26 PM   #15
BlueJeep
BlueJeep's Avatar
I actually prefer the torch for things like this, because the head of the plasma is thicker and harder to get up close, so you end up having to gouge it out rather than slice it off....leading to more sparks shooting back at you. That's my opinion. And, I cut the heads off on the outside, that way I didn't have to drive out the part that was in the frame. Comes off easier that way, and since they need to be shortened to go on the s10 frame, it doesn't matter if you get into the bracket a little.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 02-17-2010, 07:30 AM   #16
Dan Bowles
AD Addict
I bought a cab from a guy and the whole set were already off and in side...that's the EASIEST way to deal with those pesky rivets.
Old 02-18-2010, 10:38 AM   #17
1952ssr
1952ssr's Avatar
I ground the rivet heads off with a 3 1/2 grindin disk then hit with a hammer. But, strange thing I found was my '52 long bed and '47+/- rear frame portion the hangers from the '52 were longer than the other two. Here are some pictures, please don't make fun of my welding skill I am learning. Pictures are from front to back.
