Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 02-16-2010, 03:02 PM   #1
jawilder
Coke for rust removal
My front bumper was covered in light rust so I poured a can of coke on it and wadded up a handfull of aluminum foil and scrubbed away.
I couldn't believe how fast it came off! I will be trying this on my mag wheels next.
I don't think I would try this on a show truck as the foil might have scratched the chrome a bit, but for my rig it was perfect.
jawilder is offline   Reply With Quote
Old 02-16-2010, 03:35 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Coke for rust removal
I've heard of using soda on your battery terminals to get rid of acid build up, but never for rust. Glad to hear it work for you!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-18-2010, 04:36 PM   #3
DT1
DT1's Avatar
Ive actually seen Coke tested on chrome and it had favorable results. I think the show was Myth Busters.
DT1 is offline   Reply With Quote
Old 03-03-2010, 09:22 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
like lil specally surface rust spots? coke or pepsi (everythings coke in the south lol)
John
1999 Toyota Tacoma 4x4
Old 03-04-2010, 01:07 PM   #5
jawilder
Well, being a Texan, I won't allow Pepsi into my home, so yes, Coke. Just pour it on and rub it off with wadded up aluminum foil. Works like a charm on chrome!
Old 03-04-2010, 01:34 PM   #6
mbgmike
look what it does for teeth
mbgmike is offline   Reply With Quote
Old 03-04-2010, 09:29 PM   #7
oldblue1968chevy
so pepsi or coke?
LOL
John
Old 03-05-2010, 03:36 PM   #8
michael bustamante
michael bustamante's Avatar
so if it eats rust, imagine what it does to your guts????
1967custom
michael bustamante is offline   Reply With Quote
Old 03-05-2010, 05:28 PM   #9
oldblue1968chevy
gotta have that sundrop (for you folks in the south) yum
John
Old 06-09-2010, 01:09 PM   #10
93Chevy4x4
My grandfather restores peerless automobiles. When the motors are seized on his projects he pores coke in the motor and trys to turn it over a little everyday eventually there good as new. Just drain the coke out and fill with motor oil.
-1993 Chevy 1500 2wd, reg. cab shortbed, V6, Dual Exhaust
-1993 Chevy 1500 4x4, Reg. Cab, stepside, Currently doing a frame up.
-1985 Chevy S-10, 4x4, 355, Tons of Extras.
-1989 Chevy S-10 ex cab, V6, parts truck.
-1995 GMC Jimmy 4x4, Vortec V6.
-2008 Chevy Aveo.
93Chevy4x4 is offline   Reply With Quote
Old 06-24-2010, 02:05 AM   #11
67chevy1series
67chevy1series's Avatar
man coka cola and tin foil dang it does work my orignial chrome bumper went from mest up to good enough to install on your truck thanks guys
67chevy1series is offline   Reply With Quote
Old 08-12-2010, 05:39 AM   #12
fryer1979
Redneck Hillbilly
fryer1979's Avatar
I've done the battery terminal clean up with Coke for years, but I have never heard of it working on rust. Very kool, now I've got something else to try.
fryer1979 is offline   Reply With Quote
Old 10-22-2010, 07:25 PM   #13
speesh
speesh's Avatar
Talking Re: Coke for rust removal
"so if it eats rust, imagine what it does to your guts????"
If we go by that, look what water does to our trucks! I am never drinkin water again!!!!
57 suburban(sitting in the driveway), 2 69 C20 longbeds (sitting in the field ) and a 2003 8.1 Suburban
Endeavor to persevere.
"All of a sudden, I'm the old timer!" Some old timer on American Pickers.
speesh is offline   Reply With Quote
Old 11-23-2010, 03:56 PM   #14
Short Circuit
Short Circuit's Avatar
That's why you're supposed to drink Coke after drinking water. The water creates the rust and the Coke removes it.
66 C10 Short Wide BBW
68 AMC Rambler American 440..all original..53,000 miles
1999 Corvette Coupe...cold air intake and 20's
2006 F**d F-150 Super Crew
2007 F**d Ranger Ext. Cab
Short Circuit is offline   Reply With Quote
Old 11-23-2010, 04:19 PM   #15
RLTW375
Cleaned my battery terminals with it and it worked great. Just remember to spray off your driveway, mine is permanently stained....or eroded
72 CST Blazer 4x4 (Revival in progress)
http://67-72chevytrucks.com/vboard/s...d.php?t=430968
RLTW375 is offline   Reply With Quote
Old 12-02-2010, 02:17 AM   #16
treveiger
treveiger's Avatar
We had a battery explode on a floor scrubber and the inside was filled with acid so we got a coke and poured it all over the machine and good as new
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 12-25-2010, 03:09 AM   #17
67chevy1series
to all MEMBERS COCA COLA OR PEPSI , POUR IT ON YOUR RUSTY PATINA FENDER OR HOOD AND THEN USE TIN FOIL AND KEEP RUBING AND REPEATING THEN WASH IT OFF WHEN YOU THINK IT IS OKAT IT WILL TAKE OFF THE RUST AND BRING OUT THE BLACK OR RED PRIMER COLOR UNDERNEATH AND MAKES IT LOOK COOL RAT ROD STYLE
Old 12-26-2010, 03:38 PM   #18
BusinessProfessor
I use a small bucket of Coca-Cola to remove rust from bolts and small parts. Soak overnight, rinse and clean with wire brush. Presto---Rust Disappears!!!
BusinessProfessor is offline   Reply With Quote
Old 12-26-2010, 05:02 PM   #19
67chevy1series
Old 12-28-2010, 08:59 PM   #20
Altec
Getcha Pull
Altec's Avatar
I remember the episode of Mythbusters where they tested this. The bumper they did looked great. But when they cleaned battery terminals, it seemed as though that the fact that it is a liquid was the only thing that helped. Water did just as good of a job. At least, that is what I remember. Haven't seen the episode in a while, and I have proper supplies for cleaning batteries lol.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 12-29-2010, 12:19 AM   #21
bubba327
HOW long until spring??
bubba327's Avatar
Hey guys I was just passing through reading the posts and thought this old thread might interest you .
"Rust removal using electrolysis."
Uses a battery charger and wash soda
http://67-72chevytrucks.com/vboard/s...d.php?t=385635
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 12-29-2010, 01:47 AM   #22
Altec
Getcha Pull
Altec's Avatar
Man, that is cool. Gotta try that out. I got plenty of rusty parts!
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Old 04-22-2011, 12:36 PM   #23
BusinessProfessor
I've found that the best cleaner for battery terminals is WD-40 then Light sanding and a repeat of WD to remove the dust.
Old 05-22-2011, 02:52 AM   #24
BruthaMan
US Army Veteran
BruthaMan's Avatar
A pencil works good on removing light surface rust. When I was in the Army, back in the eighties, my section chief showed us that trick for getting surface rust off our M16s.
BruthaMan is offline   Reply With Quote
Old 05-22-2011, 07:53 PM   #25
Torrey72
Rollin in my K5 toaster
Torrey72's Avatar
I use Coke to remove Rum from a tall glass. I just add the coke to the rum and drink. It works every time
Torrey72 is offline   Reply With Quote
