Old 02-16-2010, 03:20 PM   #1
rcbildr
rcbildr's Avatar
Need help with electrical problem
I have bad eletrical connection somewhere in my 85 Suburban. It loses power just enough to shut down the engine and it does not happen consistently....I see the volt gage jump when it happens. I'm pretty sure its somewhere on in the main power wiring. Could this be a sign one of the fusible links is going bad? I'm going to double check the connections at the starter and alternator again, but I'm thinking I'm missing something. Does anyone have any other ideas? Thanks!!!
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 02-17-2010, 02:40 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Need help with electrical problem
Anyone?
tvblazer78 is offline   Reply With Quote
Old 02-17-2010, 10:05 PM   #3
Daggar
Daggar's Avatar
On my 87 I had the same issue. Occasionally while driving usually after a bump my engine would die. The Positive wire that runs to starter has a connector on it were the wire goes from 12 awg (aprox) to 14 awg (aprox). My stupid connector started to corrode and at first I thought it was a fuseable link but after disecting it I found it was just a palin connector. So I cut it out and soldered the 2 wires together and weatherproofed it. The problem never reoccured after that
1999 Chevrolet Suburban 2500 4x4 - 454, 4L80E and lots of other fun options
1967 Chevrolet C10 Longbox Stepside - Restored
1991 Chevrolet Suburban 2500 4x4 - 350, 4L80E - Not dead but severly crippled
1987 GMC Suburban 1500 - Now some retired guy's trailer hauler
1992 Lumina Z34 - I'll miss that PITA
Daggar is offline   Reply With Quote
Old 02-18-2010, 11:04 AM   #4
rcbildr
rcbildr's Avatar
Weird thing is with this problem, I can go over bumps...I have to cross railroad tracks to get out of my neighborhood...and the truck is fine. When I get some free time at home I'm gonna check that connection and make a new fusible link.
My Projects:
1978 Camaro Z28
Old 02-25-2010, 10:40 PM   #5
muddyblazer02
muddyblazer02's Avatar
check all the grounds. take them loose and clean them and reinstall. start with the simple stuff and you will usually find your problem.
Ken
truck junkie
muddyblazer02 is offline   Reply With Quote
