Old 02-22-2010, 08:47 AM   #1
78-5.3
78-5.3's Avatar
door hard to close
my pass door is hard to shut it drives me crazy i dont wanna slam it to shut it!!! i tried adjusting the striker but it did nothng?
i read that latches on these are different between years anyone have info on this ? what ae the differrances
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 02-22-2010, 08:52 AM   #2
menace121978
menace121978's Avatar
Re: door hard to close
is there a big plastic washer on the striker? if not you need one.
eastwoods also sells a door adjustment tool that works really well from what i have heard. aka "butta tool"
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 02-22-2010, 09:32 AM   #3
diponyou
diponyou's Avatar
also i read that if your cab is sealed really well that the pressure cant escape and thats what causes a hard shut.
if thats the case try to see if rolling the window down a little and shutting it makes it any easier?
and if it is i think you just gotta wait for the seals to break in a little.
or find a way to relieve the pressure.
diponyou is offline   Reply With Quote
Old 02-22-2010, 09:45 AM   #4
78 Chevyrado
When i have the windows up, i have to keep my hand on it to shut it, i dont have to slam it or shove it closed, just keep a hand on it. but with the windows down you can dang near click it shut from like an inch open. on my 77 I totally removed the vents in the lower rear of the door and it helped, but then you get a draft on the highway at 70+mph
78 Chevyrado is offline   Reply With Quote
Old 02-22-2010, 09:48 AM   #5
78-5.3
78-5.3's Avatar
i noticed on the stricker there are about 3 metal washers ? i will have to see if there is anyone plastic ones
Old 02-22-2010, 11:50 AM   #6
nlped
nlped's Avatar
It's not a plastic washer, he means a plastic "sleeve" on the striker itself.
Oh, and I can vouche for the "butta tool" It works great!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 02-22-2010, 11:57 AM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
are you sure that the hinges arent bad? alot of the time there is play in the pin and you need to get a kit to make the door shut correctly. The kit contains a new pin and bushings to get rid of the oval shape caused by wear
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-22-2010, 11:58 AM   #8
slammed longbed84
This is not ad space
slammed longbed84's Avatar
also on top of makn sure it has the plastic sleeve put some grease on it and the latch that helps treemendassssllly!!!!
slammed longbed84 is offline   Reply With Quote
Old 02-22-2010, 12:04 PM   #9
raws67
raws67's Avatar
Also check to make shure your hinge pins for wear since its only your passenger door you can probably rule out the seals. Open your door about five inches grab the back of the door and try to lift it up and down. If they are worn you will know right away. They make rebuild kits for the hinges and they work good and relativly inexpensive. Usually the plastic bushing will wear out when the hinges are misadjusted or just worn out.
raws67 is offline   Reply With Quote
Old 02-22-2010, 01:57 PM   #10
Oldschool82
Balls to the wall!
Oldschool82's Avatar
I too have these problems, so thanks for the tips guys.
Oldschool82 is offline   Reply With Quote
Old 02-22-2010, 10:24 PM   #11
6772fan
Active Member
6772fan's Avatar
My experience with the problem you described says that normally the plastic sleeve/bushing missing is the culprit. You can get them at the HELP section in most automotive stores. They're not expensive and pretty easy to replace, unless you have a problem removing the striker bolt that's sometimes frozen in place.
Lane
1979 Chevy SWB- (Second owner- Father in Law was first)
1979 Chevy Silverado SWB-Red/Red
6772fan is offline   Reply With Quote
Old 02-22-2010, 10:40 PM   #12
bumslie75
bumslie75's Avatar
i think i need the sleeve thing too
"There he goes. One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die."
bumslie75 is offline   Reply With Quote
Old 02-22-2010, 11:29 PM   #13
GMC Guy
GMC Guy's Avatar
i put eletrical tape around the striker in place of the sleeve. only cuz i can't get those ******* things loose....
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 02-23-2010, 12:29 AM   #14
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
My diagnostics order......
1] Plastic sleeve on the Nader pin. If you pin won't budge, a quick rap with a hammer will usually loosen then. Use a long handled ratchet or bar to break it loose.
2] Worn hinge pins. Find them in the HELP section at any parts store. Easy to do.
3] The "butta" tool. Aligns and tweaks the hinges after replacing the hinges or hinge pins. I used mine all of 5-10 seconds, but was well worth it.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 02-23-2010, 12:30 AM   #15
willett
Another Day, Another Dollar
willett's Avatar
who sells the kit??
i need one too!
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 02-23-2010, 12:34 AM   #16
glock35ipsc
Originally Posted by willett View Post
who sells the kit??
i need one too!
Bob
Old 02-23-2010, 03:39 AM   #17
spinem
haha, ford guys...
replace door pins?
spinem is offline   Reply With Quote
Old 02-24-2010, 05:11 PM   #18
Alias137
Alias137's Avatar
So what part number is the mysterious "butta tool"? I checked eastwood's site, and there is nothing there by that name. I understand it is a trade name, so there are 2 door alignment tools there. P/N 43674 is one for 29.99, and the other is P/N/ 14088 for 59.99. The 59.99 one looks like it has some serious leverage behind it. I need to align my doors too, so I would like to know which one you guys used. Thanks!
Alias137 is offline   Reply With Quote
Old 02-24-2010, 05:32 PM   #19
glock35ipsc
A while back, I bought one to tweak my doors, and proclaimed that they now shut as "smooth as butta!" Thereafter, it became known as the butta tool!
Get the $29.99 one. That's what I have.
Bob
Old 02-24-2010, 05:36 PM   #20
low86c10
new door pins and bushings more than likely just replaced mine, $10 lmc
low86c10 is offline   Reply With Quote
Old 02-24-2010, 05:47 PM   #21
GMC Guy
GMC Guy's Avatar
i'm going to be buying one of the "Butta Tools" pretty soon. but i'm curious on how they work? does it just line up the latch and striker so you can tighten the hinge bolts?
Greg
1974 GMC
L33 5.3/4l65e
.................__
Old 02-24-2010, 05:50 PM   #22
Tony_SS
Tony_SS's Avatar
I used elec tape as a quick fix on mine.. it does the trick!
Tony_SS is offline   Reply With Quote
Old 02-24-2010, 05:53 PM   #23
Dooley Dude
Dooley Dude's Avatar
Mine used to be hard to close. I replaced the strikers because the sleeve was worn. Got them from LMC for like 9.95 apiece. Probably could have got 'em cheaper elsewhere, but that absolutely fixed my problem. I did nothing else, and they close perfectly now.
And as I recall, they were a bugger to get out. If you have an entire new striker, as I did, you don't need to worry about tearing up the old one. I think I used a pipe wrench to get mine out, even after applying PBlaster. Nothing can resist the pipe wrench!
Dooley Dude is offline   Reply With Quote
Old 02-24-2010, 10:36 PM   #24
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
I bought the silencers from the dealer. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 02-24-2010, 11:39 PM   #25
78-5.3
78-5.3's Avatar
To replace the pins does the door need to come off ????
