Tahoe sun roof drains??????
Got a buddy with a 2002 Tahoe that is leaking water through the overhead console---an I suspect the sunroof drains may be clogged with dirt. Anyone familiar with this??? Where do the Tahoe drains come out??? Any easy way to clean them to ensure proper drainage?? I know from personal experience on other vehicles that poking a wire down the drain or using air pressure can dislarge the small rubber hoses which creates a major PITA!!!
Help, Help!! |
![]() Join Date: Jun 2006
Re: Tahoe sun roof drains??????
Front hoses come out above sunvisors and run down a pillars. Rear ones come out just behind b pillar area off sunroof frame. Very light careful air pressure is ok. I would make sure the seal around the glass is clean. I see a lot of dirty seals letting excess water into drains causing overflow.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
