02-23-2010, 10:09 PM | #1 |
73-87 C10 ls1 swap guys, what headers have you tried that did or DID NOT fit?
I am still searching for headers for my swap and I am not satisfied
So far i have been told that Pacesetter F body headers will fit with a little work. That is good and i may try them but there are many othe headers out there that i wonder about. so if you have tried ANY headers that fit or did not fit please let me know. Once the list is made it will be great for future swaps. I will update the list as i get the info. Will fit: 1. 2. Will fit with work" 1. F body pacesetter headers DID NOT fit. 1. Doug thorely headers for the 67-72 c10 If you have tried any of these please let me know. 1. GTO headers 2. 99-06 silverado truck headers 3. 07-10 truck headers 4. hooker 67-69 camaro swap headers (i have a set of these and they look like they may fit. 5.mid length F body headers 6.??
WTB 73-87 SWB fleetside bed!! 85 C10 6.0 project 69 camaro ls1 / t56 90 mustang lx 75 bronco injected 351w |
02-23-2010, 10:23 PM | #2 |
Re: 73-87 C10 ls1 swap guys, what headers have you tried that did or DID NOT fit?
Street and performance fit. Just call and talk to Mark, tell him what you have and what tranny(important). Pricey but look good and fit.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
02-23-2010, 10:36 PM | #3 |
haha, ford guys...
02-23-2010, 10:45 PM | #4 |
Formerly- 1972SuperCheyenne
I'm sorry but that doesnt tell him anything. As said earlier in that post, it's not even a 73-87 frame pictured. I dont trust the guys at BRP, lots of promises and no proof of anything.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
02-23-2010, 10:50 PM | #5 |
I think I'm gonna swap the flanges on some big block headers and have them ceramic coated. Seems like the best way to get true big/long tubes.
02-23-2010, 10:51 PM | #6 |
And that brp crossmember for our trucks looks like they smashed exhaust tubing in a vice.
03-22-2011, 01:35 PM | #7 |
Wow! SatisTraction,
what a great idea! this way we have a small library of different options instead of all of us running the same header that one board member found and then every one just copies that person. well here is my contribution to the "does not fit" its the edelbrock 65022 I tried bolting them om on to an 86 with a 6.0L that uses the TransDapt adapter plates 4572, these are the adapter plates that bolt on to the factory small block location. hope this helps somebody! the drivers side bolted on as you will see in the pictures but there is maybe 1/8th clearance between the header and the frame. Passenger side does not even bolt on, the header his the frame and motor mount saddle. I hope more people will contribute to this thread as it will place all the header information on one thread as opposed to reading thru build threads that wile very informative, some times its hard just finding the specific info you need
51 Chevy 3100 Deluxe Cab(SOLD) 65 **stang 6cyl 70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD]) 72 C10 Short Bed Fleetside 73 Blazer 2WD Catalina Blue White Top(Needs Love) 73 Blazer 2WD Work in progress LT1/4L60E 83 Grand National (SOLD) 94 Blazer K1500 Silverado (SOLD) 96 Impala SS All original (NEXT IN LINE 2 B SOLD) 99 Tahoe 2DR, 2WD |
03-22-2011, 03:14 PM | #8 | |
Home Built '87
I bought mine from Mark, they took a while to show up but I think that\s because I'm in Alberta. They aren't cheap --- you just have to tell him exactly what they are bolting onto and what kind / year truck frame you have. There was one other thing he needed to know but I'm out of town right now and don't have my notes with me to check, will edit once I remember.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
03-22-2011, 08:45 PM | #9 |
You can get some from Street & Performance like I did. Very nice quality & fit - they build them custom in-house. Bunch of different applications. Worth a shot!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
03-23-2011, 12:40 AM | #10 |
any one got a part number on the s&p headers? so that SatisTraction can update the list he started?
03-23-2011, 12:50 AM | #11 |
Home Built '87
I had a thread in LSx swaps asking for a part number on these headers....not a reply in weeks.
I think you just have to call Mark and tell him your application.
03-23-2011, 02:09 AM | #12 |
Yeah, that's what I did - just called them up & gave them the application info - they go from there. May have been a part number on it when it arrived at the shop but I never saw it sorry... They are very helpful though there at S&P.
03-23-2011, 02:12 AM | #13 |
BAD BOW-Silverado XST
Here is a complete conversion article: http://www.hotrodlane.cc/77chevytruck/77chevy.htm
06-20-2011, 08:24 PM | #14 |
adding to the list I have an 86 K30 with advanced adapter mounts this is a 4x4 truck
DID FIT: the 88-98 shoenfeld ls swap headers fit with trimming the D/S frame about 1/2 but collector is very close to shifter but no interference, P/S fit with cutting off trans ear but is almost touching my vaccum modualtor on the th400 DID NOT: Someone recomended 73-87 BBC headers and LS flanges, no way. for one the head is on more of a downward angle so the headers flare way out. Even after heating and bending them straight they would not work with the LS flange because the tubes hit each other and I was about 1" off the last port. These would take extensive modification of the tubes to work. Last edited by fgrecycling; 06-20-2011 at 08:25 PM. |
06-20-2011, 10:33 PM | #15 |
BMW & ASE Master Certified
I am running the 99- style 5.3 pace setter headers on my truck fit is retarded close even after dinging some of the tubes. on occasion i get a header to frame rattle. They work for me... i made my own adapter plates.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
11-26-2013, 10:59 PM | #16 | |
12-22-2014, 12:31 PM | #17 |
Did the Hooker Headers interfere with the gear selector? If so how did you fix it?
12-22-2014, 05:02 PM | #18 |
I have Hooker Hustlers (mid) installed. I had to trim engine mount shells a little. But otherwise they went right in.
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
12-22-2014, 08:07 PM | #19 |
What about the OBX truck headers for 99+ Vortec trucks? I had those on my 2003 Silverado SS and loved them.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
12-23-2014, 05:23 AM | #20 |
Diggin The SquareLife
I seen ppl use trailblazer ss headers
also schoenfield headers an these jus came out not long ago http://www.streetlegaltv.com/news/ne...ed-73-87-c10s/ |
12-23-2014, 08:13 AM | #21 |
I went thru the header thing on my 82 2wd . Schoenfield headers did not fit very well . Touched the upper control arm and was not much clearance for the stock linkage at all.
Got wind of someone using a Dynatech long tube 70-81 camaro header and holy cow these thinks fit like they were made for it . Cleared everything . If your looking to use stock linkage these will work. .They were a long tube so they pointed at the trans cross-member .I did not want to jockey it over so I changed it out to one of summits 3" rise round universal one so the exhaust would shoot straight back. Looks like it was made for it . I would highly recommend these for your swap . Last edited by homemade87; 12-23-2014 at 08:23 AM. |
12-23-2014, 01:35 PM | #22 |
Ive got the trailblazer ss long tubes made by pacesetter on mine. They fit great but I am running a porterbuilt dropmember in my truck.
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy |
12-27-2014, 07:41 PM | #23 |
I used the Muscle Rods Hedman headers on my LS swap. I had zero issues. They were a shorty header granted.
Instagram @maxh15 #maxhtrucks |
12-27-2014, 11:59 PM | #24 |
I also went with the Hedman Muscle Rods for my LS3 swap and they fit great.
12-28-2014, 03:55 PM | #25 |
Hooker cast iron fit like GM designed them to.
Scotty Baccus |
