Old 02-27-2010, 11:03 AM   #1
chevelle518
Exclamation Remove Steering Column
How do you remove a steering column from a C30 pickup.
chevelle518 is offline   Reply With Quote
Old 02-28-2010, 12:38 AM   #2
dkb1970
dkb1970's Avatar
Re: Remove Steering Column
Is it that much different than a C10? I thought you just unbolt it at the plate just inside the firewall and unbolt at the joint near the steering gearbox and pull the whole assembly out thru the cab? Hopefully someone with experience in this will chime in soon. Good luck.
Dennis
dkb1970 is offline   Reply With Quote
