Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 03-03-2010, 12:41 PM   #1
72-c20
Packrat
72-c20's Avatar
'72 K20 w/4" lift.
72 K20 long bed w/4” lift (blocks in rear)
350/TH350/205
D44HD front axle, 4.10
Eaton HO54 Full Floater Rear Axle, 4.10
has rocker rust and cab floor rust, but better than normal for Iowa trucks...
New Stuff put on.
gas tank, sender, grommet, cap
Crate 350 Engine, dual exhaust
heavy duty trans cooler
shocks
overload spring leaves for rear
Holley 600 cfm carb, electric choke
carb adapter
4-core radiator
heater core
285/75R16 Firestone Destination AT tires (33”)
neoprene seat cover
Master Cylinder and Booster
gas pedal
D44 large bearing spindles and installation incl. shafts, ujoints, etc…
Spicer D44 upgraded u-joints
heater controls rebuild kit
front bumper bolts
transfer case full reseal
battery tray
front upper and lower ball joints
dome light lens
assembly manual
wiring manual
Haynes manual
heater fan switch
tie rod ends
front axle pinion seal
rear axle pinion seal
halogen headlights
rear brake lines, shoes, cylinders, seals, 2 tail pipes
custom made heavy duty running boards, D44 pinion seal labor
Used Stuff I put on it.
seat from '69 GMC
tailgate
hood
cowl
16x7 Chrome Blade style wheels
grill and surround, logo
mirrors
front axle shafts (later model D44)
topper
Late 70's steering wheel
seat belts (3 people)
chrome front bumper
door weather seal
antenna
Stuff Not Installed that goes with it….
Warn Premium Locking Hubs, New
Rubber Cab Mount kit, New
Rocker panels, New
door hinge pin kit, New
hood cushion set, New
floor support overlap sheet metal, new front & Rear
8mm plug wires
modified gauge cluster, tach, volt
rear sliding window
glove box lock and key
94 amp alternator, internally regulated
gone: --'07 Tahoe LTZ 4WD
--'68 Firebird 400 Convertible
gone: --'72 Chevy K20
72-c20 is offline   Reply With Quote
Old 09-29-2010, 04:20 AM   #2
lghtng2
Re: '72 K20 w/4" lift.
Is this for sale? if so need details~
lghtng2 is offline   Reply With Quote
Old 09-29-2010, 10:05 AM   #3
72-c20
Packrat
72-c20's Avatar
No for sale. I was thinkig about it, but ended up selling my '96 Yukon instead... and made this my tow rig...
Old 09-29-2010, 01:44 PM   #4
lghtng2
ah i see i see, well let me know if you spot any 67-72 4x4 leaf spring chassis roller's or frame around your area I'm in need of one asap
