Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-05-2010, 09:36 PM   #1
iluvmy72
auto to manual swap...is it hard
I might be getting a 1994 blazer with a 4.3 and auto....I'd like it to be a stick shift....is the swap hard or should I bag the idea?
iluvmy72 is offline   Reply With Quote
Old 03-07-2010, 05:39 AM   #2
FLEET72
FLEET72's Avatar
Re: auto to manual swap...is it hard
It depends on what you consider hard.
Find a donor and get: pedal assembly, get the clutch safety switch while your at it as well as any cruise control switches if you truck is equipped.
It's easier to remove if the steering column and dashboard are out of the way. There is also a 10mm bolt on the top that needs to be removed. You can see where it was in the picture below.
The hydraulic clutch (master cylinder, reservoir, actuating rod, hoses, slave cylinder and rod) parts you can decide if you want to use the donor or new. I would recommend new. Flywheel / disc / pressure plate, Transmission / bellhousing / dust cover, throwout bearing, pilot bearing. May need to change crossmember and driveshaft yoke as well as lengthen/shorten shaft but don't know for sure because I haven't attempted to do it yet, only started to gather parts.
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 03-10-2010, 07:37 PM   #3
crazycory1
Its not just the trans you have to swap. Because of the year of your truck, it has a 4l60e trans in it.
The ecm controls the trans.
You will need to swap the whole wiring harness and ecm from a 5 speed donor truck.
If you don't your ecm will just throw codes and retard the timing.
I know because I tried this swap with out the ecm on a 93 with out changing the ecm.
crazycory1 is offline   Reply With Quote
Old 03-10-2010, 10:45 PM   #4
FLEET72
FLEET72's Avatar
Originally Posted by crazycory1 View Post
its not just the trans you have to swap. Because of the year of your truck, it has a 4l60e trans in it.
I know because i tried this swap with out the ecm on a 93 with out changing the ecm.
ouch!
Oscar
'95 Jimmy 4X4
