Old 03-07-2010, 09:27 PM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
$14.50 and OH #$%!!
$14.50 for a Texas road safety inspection!! The test driver had a huge smile on his face. I told him have fun. He went on a short ride around the block. The lube place guys always open up the hood just to google.
Now the OH @#$% part. I noticed the truck idled a little different yesterday. Rocker arm clatter was a little louder than normal. I expect it since the truck has not moved in over a week. Later that day, I went to visit my sister. Well, I had to limp her home at 1500 RPMs in OD. A rocker arm or push rod has probably failed. The clatter is so obvious. I know the engines are known to have weak push rods. They flex under high stress. Lets just stay, there are plenty of tires marks all over town.
I hope to pull valve covers and check valve lash. Maybe it's time for upgrades!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-07-2010, 09:53 PM   #2
Cherub
Cherub's Avatar
Re: $14.50 and OH #$%!!
was it the inspection shops fault???
Cherub is offline   Reply With Quote
Old 03-08-2010, 12:16 AM   #3
gchemist
gchemist's Avatar
Nope, I bet he didn't even get out of second gear during the test drive. Inspectors have to follow strick policies. Besides, they are in plan view during the test drive.
Old 03-08-2010, 12:23 AM   #4
Cherub
Cherub's Avatar
oh gotcha i read the original post wrong then. Good thing about out something breaking you get to but go fast parts hehehe
Old 03-08-2010, 12:54 AM   #5
spinem
haha, ford guys...
dennngggg! i know how that goes
spinem is offline   Reply With Quote
Old 03-08-2010, 01:11 AM   #6
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
So did you pass your inspection?
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 03-08-2010, 02:56 AM   #7
gchemist
gchemist's Avatar
The tester was happy. He didn't check the gas caps or anything under the hood. Not even the windshield wipers. Another easy inspection until next year. Just for fun, I dropped it in first leaving the station. I turned up the street to my house and let the ZZ4 loose. Tire smoke for a block.....then I wonder why the rocker arms are clanging.
I'm borrowing a friends rocker arm clips. I'll be able to run the motor without oil squirting everywhere. The rockers need to be set at zero lash + 1/4 to 1/2 turn. Now that my tach is working, I'm going to adjust timing to specs. 10 degrees @ 800 RPMs. I'm pulling out the vacuum gauge and adjust the carb if needed.
Old 03-08-2010, 11:47 AM   #8
Driveway Dreams
I have car A.D.D.
Well, get to it. No sense beating up your internals too bad. Glad to hear you passed even with issues. You all remind me that I am glad I don't have inspections, emmissions, etc.
-Gerald
Old 03-08-2010, 12:22 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Yikes! Don't blow this up. I would hate for you to have to dust off the old 305 out and rebuild it...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-08-2010, 02:45 PM   #10
Pyrotechnic
Pyrotechnic's Avatar
If you're lucky the stock lock nuts just backed off. Good time for a rocker upgrade.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 03-08-2010, 09:55 PM   #11
gchemist
gchemist's Avatar
I'm almost shamed to post these pictures. Oil change is due.
Okay, I did not find any damage. I removed both valve covers. Sure enough, nearly all the rocker arms were loose. Some even took a 1/4 turn! Ouch. I'll adjusted them snug without a feeler gauge. Factory setting is zero lash. I should have adjusted them before installing the engine. A friend is letting me borrow some rocker arm clips. I'll run the engine while adjusting them to zero lash + 1/4-1/2 turn. The valve train noise should be quieter. Now that I got the air cleaner off, I'm setting the timing to specs. 10 degrees at 800 RPMs.
Who wants to help???
Old 03-08-2010, 10:18 PM   #12
Pyrotechnic
I'll be in Austin this weekend, and if I can swing it I want to try and make it to the Cedar Park show. I get back Friday evening and the truck is filthy so lots of cleaning to do before Saturday morning. Would be cool to have all the 73-87's lined up!
Old 03-08-2010, 11:38 PM   #13
gchemist
gchemist's Avatar
I plan to e-mail with a list. I'll ask them to save 10 spots for square body trucks!!
Old 03-09-2010, 09:41 AM   #14
cableguy0
Hydraulic lifters should not "lose" adjustment. Either the nuts backed off (highly possible) or your cam is going south. Something caused them to be loose whether its wear or the nuts backing off either way readjusting isnt going to fix the problem. It will happen again
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 03-09-2010, 11:12 PM   #15
gchemist
gchemist's Avatar
The lifters are hydraulic rollers. Nuts just backed out. I'll know after adjusting then driving like I stole it. I can use a little locktite if necessary.
Old 03-09-2010, 11:55 PM   #16
Red_69
Red_69's Avatar
Mark sure your studs aren't pulling out. Unlikely but I've had it happen with press in studs.
1986 Chevy 3/4 Ton 4X4
Red_69 is offline   Reply With Quote
Old 03-10-2010, 12:59 AM   #17
gchemist
gchemist's Avatar
Yea, I'm not too concerned right now. The orginal ZZ4 owner ran it hard. Or he would have not totaled his late 70's Vette. LOL. Only one rocker is making noise now. I should find it tomorrow. I'll snap a video during the adjustment.
Old 03-11-2010, 04:36 PM   #18
Pyrotechnic
Gerardo, what time are you going out to the show on Saturday ?
Old 03-11-2010, 04:40 PM   #19
gchemist
gchemist's Avatar
I emailed the sponsors. I'm leaving my house around 8:00 AM. It should take me about 35 minutes to arrive. Start time is 9:00. I want to be there right before they get started. I've asked for 5-7 spots for square body trucks. I've counted at least 4-5 as of today.
Old 03-11-2010, 05:43 PM   #20
Pyrotechnic
Cool I just talked to my dad, we'll be there.
