Old 03-08-2010, 04:54 PM   #1
es67chevy
es67chevy's Avatar
How Did You Finish Your Serpentine Brackets???
We bought a GM Performance serpentine setup for our truck and the aluminum brackets do not look the best. There are a lot of nooks and crannies in the brackets that make them hard to polish or paint, etc. So, what did you do to your brackets? Did you leave them as they came? Did you paint them? Powder coat them? Pictures are helpful if you have any. And any tips on what didn't work for you if results were less than satisfying.
Here is what our setup looks like mocked up without any finishing done to the aluminum brackets:
Eric
1967 C10 SWB
383 Stroker/TH400
Brother's One Piece Power Windows
Shaved Doors, Markers, and Bumpers
4/6 Early Classic Drop
Rear Fuel Tank (49-52 Chevy Car Tank)
Surf Blue Paint
Bella Vista, AR (Arkansas for those that get the 'A' states mixed up)
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869
es67chevy is offline   Reply With Quote
Old 03-08-2010, 04:59 PM   #2
JohnC
JohnC's Avatar
Re: How Did You Finish Your Serpentine Brackets???
I'm going to run the same brackets on my engine too, whenever I get them. I was either going to clean them up, and have them cleared with powdercoating, or paint them. I haven't decided on what color though. So I would like to see what people have done with theirs as well.
JohnC is offline   Reply With Quote
Old 03-08-2010, 05:08 PM   #3
es67chevy
es67chevy's Avatar
Yeah, and I've heard that powdercoating causes problems with moving parts. So could cause problems with the moving parts that are built into the brackets. Would love to confirm if others experienced that or not.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-08-2010, 05:12 PM   #4
JohnC
JohnC's Avatar
I was just going to have the main brackets powdercoated. None of the pulleys, or tensioners.
Old 03-08-2010, 05:38 PM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
I sanded, cleaned, primed, and painted my son's
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-08-2010, 05:40 PM   #6
JohnC
JohnC's Avatar
Any pics of them?
Old 03-08-2010, 05:47 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've powdercoated several sets of them and they turned out very nice. I had to preheat them before coating though as the deep recesses will not take powder when they are cold.
Old 03-08-2010, 07:50 PM   #8
Fitz
Powdercoat to match aluminum alternator housing & intake manifold.
Fitz is offline   Reply With Quote
Old 03-08-2010, 11:23 PM   #9
es67chevy
es67chevy's Avatar
Awesome. And no problems with the parts locking up that can't be taken apart?
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-08-2010, 11:24 PM   #10
es67chevy
es67chevy's Avatar
Thanks for the pics. I bet it was a lot of work to sand every nook and cranny these things have. How long did it take ya?
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-08-2010, 11:27 PM   #11
es67chevy
es67chevy's Avatar
Yeah, that's the color we were leaning towards. Glad to get a second opinion about that. Thanks!
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-08-2010, 11:30 PM   #12
Tx Firefighter
If some part can't be removed from the component, just have the coater mask it off. Lots of folks don't realize it but powdercoaters can mask anything you ask them to. We use high temp tape that the oven doesn't bother and aluminum foil for more difficult or large areas. It's dead simple if your coater will go to the trouble.
But, on engine brackets like that, just remove the tensioner and idler pulleys and give it hell to all the solid pieces. Paint the delicate items to match. I'd not want to subject any bearings or seals to the heat.
Old 03-08-2010, 11:39 PM   #13
es67chevy
es67chevy's Avatar
Cool! Thanks for the tips. I had no idea you could mask off parts and still powdercoat.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-08-2010, 11:51 PM   #14
my67chevytruck
Under Construction
It took us awhile but ours was used. with your setup if you decided to have it painted, your could just clean with wax and grease remover, have primed. and paint it.
powder coat maybe the better option as its more durable than paint.... let us know what you decide.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 03-09-2010, 10:19 PM   #15
es67chevy
es67chevy's Avatar
How did you remove the power steering pump pulley? I've never removed a pulley before and not sure of the correct technique. The GM brackets came with the power steering pump already attached.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-09-2010, 10:25 PM   #16
Tx Firefighter
You have to use a power steering pulley puller. They are pressed on.
Old 03-09-2010, 10:33 PM   #17
POPO1984
POPO1984's Avatar
I would go powdercoat
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 03-09-2010, 10:39 PM   #18
es67chevy
es67chevy's Avatar
Ah cool. Thnx. Anything I need to be careful of in using one or is it pretty straightforward?
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-09-2010, 10:49 PM   #19
es67chevy
es67chevy's Avatar
Yeah, definitely leaning that way now if I can get it apart enough to have it done. Thanks!
Also, any other pics of painted or powdercoated serpentine setups will help!
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-09-2010, 11:39 PM   #20
FLEET72
FLEET72's Avatar
Having the proper tools makes all the difference in the world.
OTC from Summit Racing
And the budget one from Harbor Freight
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 03-10-2010, 08:51 AM   #21
es67chevy
es67chevy's Avatar
Very cool! Thanks. Will have to run down to my local Harbor Freight.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-10-2010, 08:55 AM   #22
my67chevytruck
Under Construction
I need to buy one from harbor freight as well. I borrowed one from the local parts house.....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 03-10-2010, 08:57 AM   #23
es67chevy
es67chevy's Avatar
Yeah, my dad and I talked about just borrowing one too. Guess you really only need it to pull it once and then press it back on once. Not sure what my odds would be that I would have to borrow it more than twice. Only $20 at Harbor Freight for one. Hmm....
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
gm performance, serpentine
