Old 03-12-2010, 07:57 PM   #1
stevieB
stevieB's Avatar
Dilema
ok, I need an opinion,
I have the choice of getting either rims or a bag setupwhat should i do????
stevieB is offline   Reply With Quote
Old 03-12-2010, 08:25 PM   #2
low88burb
Re: Dilema
bag first it will look cool even with stock wheels
low88burb is offline   Reply With Quote
Old 03-12-2010, 09:07 PM   #3
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Dilema
Bags.. Then you will know how to get your wheels. Some people like to build around wheels but it's best to have your wheels made to what you built. Did that come out right..
tvblazer78 is offline   Reply With Quote
Old 03-13-2010, 12:26 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Dilema
Wheels first. You can static drop it for now, and bag it later. To me nothing looks worse than a laid out truck on old tired rims.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-13-2010, 03:43 PM   #5
Tony_SS
Tony_SS's Avatar
Re: Dilema
I say bags first. Then you measure for clearance and decide the proper wheel/tire sizes based on the room you have.
Tony_SS is offline   Reply With Quote
Old 03-13-2010, 08:16 PM   #6
blazer2007
Re: Dilema
yea here too bag first,why buy rims that might not look right later,orig rallys look fine on a bagged truck or even nice hup caps and a good paint job on the rims and get the tires and rims when you fine the look your after
blazer2007 is offline   Reply With Quote
Old 03-13-2010, 10:37 PM   #7
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
Re: Dilema
I went with wheels and tires 1st... bags are not a must if you set the stance right.
CLASSIC87' is offline   Reply With Quote
Old 03-13-2010, 11:36 PM   #8
menace121978
menace121978's Avatar
Re: Dilema
wheels 1st here... i'll bag it later
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 03-16-2010, 10:58 AM   #9
stevieB
stevieB's Avatar
Re: Dilema
thanks guys, still alot to think about....
Old 03-16-2010, 11:41 AM   #10
87 dually burb
my short bus
87 dually burb's Avatar
Re: Dilema
I would bag it first because you may have clearance issues depending on your bag setup.
also you can get all your measurement when airred out to see how big a tire/wheel you can run.
plus a bag setup is cheaper than a nice set of wheels
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 03-18-2010, 11:46 AM   #11
dropd80s
dropd80s's Avatar
Re: Dilema
I would say wheels first, to me its better to build your suspension around your wheels. Just comes out better. And i would say a good bag job would be more than a "typical" set of rims i.e. boss, coys, ect. Also, don't skimp on the bag job. If you go with a crappy set up you will not like it and want to pull everything off. Seen it a hundred times. JMO though.
dropd80s is offline   Reply With Quote
