Old 03-22-2010, 05:24 PM   #1
Capt280
Capt280's Avatar
63 rear end
I looked through this web site and can not find the answer. I have a 63 rear end. brake assembly removed axle shafts removed. However the brake backing plate is putting up a fight how is this removed it seems it is pressed on?? it is not bolted in place.
Capt280 is offline   Reply With Quote
Old 03-22-2010, 05:54 PM   #2
dirtjumper63
Re: 63 rear end
Ya mine were a bit rusted on as well, if you have the 12 bolt rear the backing plates are pressed on with a fine spline to keep them from turning. i heated them up and hamered them off. good luck
dirtjumper63 is offline   Reply With Quote
Old 03-23-2010, 01:40 AM   #3
Heater63
Heater63's Avatar
Re: 63 rear end
Are you trying to convert to rear disc's? I didn't find any help or "bolt on" conversions for '63, because of the pressed on plate. I decided to take the easy way out and just keep drum brakes on the rear. You are going to have to do some fab/welding to mount a flange, etc. Post your progress, we would love to see your solutions. Good luck.
292 + TKO500
Heater63 is offline   Reply With Quote
backing plate, brakes, rear end
