laying frame with PB trailing arms
hey guys finaaly got started on my frame. im laying the rear with a set up from porterbuilt. i got the 3 inch drop trailing arms the tubular crossmember, the monster stepnotch and the shock mount bars/notch bridge. here a some pic of the progress.
Re: laying frame with PB trailing arms
and a few more.
low n' slo
![]() Join Date: Mar 2009
I've always loved that setup. work is lookin good man..keep the pics comin
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
67GMC Slammed
nice!! this set up will allow you to lay the frame in the rear?
my dropmembered 67 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383215 |
Looks sweet! Keep it up!
Yes sir this will allow it to lay frame, I'm going to run 24" all around and this notch can lay up to a32" tall tire mine will be around 31 1/2. Unfortunately I can only work on the truck a cupple days a week so progress might be slow. I will keep posting pics and questions Im sure I will need help.
ok guys here an update. ive been working fitting the pb stepnotch, my friend/welder wanted a "better fit and more welding surface so we dicided to box a small section around the notch. we used 3/16 plate and i got to use a plsma cutter for the first time
the front plates are inside the framerail and the rear is outside the rail. the reason is that the front is wider and the notch fits good but on the rear there is a pretty big gap, too big for me anyways.
VA72C10
![]() Join Date: Mar 2008
Looking good!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
thanks i just wish i could work on it more often.. i find my self on here looking at pics of my own truc.lol
Looking good,
You gonna love that set up! Thanks for the PICs Heres mine on a 30" tall tire |
oh my god...that thing is sick. dang it didnt you just read i cant work on my truck too often youre gonna make me call in sick
#13 |
is it me or is your notch different? it looks wider at the bottom. im gonna have to contact nate before i weld mine in.
#14 | |
![]() Not sure about the notch, that would be a question for Nate. My truck was set up for those wheels/tires and to lay frame, aired out, with a 5" ride height. I just posted those pics up to keep you motivated, dont call in sick!! |
#15 |
wont be calling in sick dont worry. i might beg for overtime after a look at your truck. thanks for the pics very motivational.
#16 |
I'm just glad to be here!
In the 1st two pics, is that bar that runs from arm to arm the lower shock mount? If so, I really like that idea.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#17 |
Yes that the lower shock bar came from Nate as part of the kit. I will have pics of the upper bar sometime next week.
#18 |
needs more $$$
1970 2wd Blazer |
#19 |
The PORTERBUILT BOLT ON BODYDROP,
will allow the pinch weld to set at the same point as the lowest part on the frame, thus allowing pinch weld to be lowest point on the truck........its still in the works but you can follow my thread. I am sure Nate will fill in with more detail eventually as more progress is made. http://www.67-72chevytrucks.com/vboa...=358687&page=9 |
#20 |
The bodydrop mounts for the cab make alot of since, are simple, and will make dropping the cab nice. Im just waiting to see how Nate aligns the bumper and what he does about the bed.
#21 | |
#22 |
wow, that set-up looks cool! Was also reading about it on the PB site...
can't wait to see some more progress!
get it! |
#23 |
plates and notch have been welded in place (sorry no pics yet) due to the weather we have not worked on the truck much but i ordered my front dropmember with pb arms and sway bar
#24 |
MY notch looks like yours .I have ran in to a problem with the panhard bar hiting in the bottom side on the notch.Didint know if you have ran into the same problem or not.
#25 |
There's a different panhard bar bracket for the weld-in notch... It looks like I sent you and Impalapawpaw the one for the bolt-in notch. The one used for the weld-in notch locates the panhard bar further towards axle center so the bar clears the notch. I will send out some new brackets to you guys this week!
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
