Can't get radio to work...
I am trying to install this aftermarket radio but i am getting no power in the harness. The original radio also didn't work. Anyone have a wiring diagram of the radio circuit for a gmc 1992 c1500?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
Chris
Re: Can't get radio to work...
I got one in my hayes manual i think if I can scan it and post a pic but I'd check fuses, maybe ones blown, and if not you need a test light to check for constant and switched power and then a ground, if nothing else run your own. You can run them out to the firewall and use the junction block under the plastic relay cover for a constant hot and a ground there for ground, or go straight to the battery, then all you need is a switched hot. You could find it in the fuse box or tap into something in the dash maybe.
turned out kinda small but maybe it'll work for ya... ![]()
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 Last edited by benoit454; 03-28-2010 at 07:37 PM. |
Thanks for that. The courtesy fuse was blown... radio now works..on to the next problem...
Chris
been there done that, mine was the exact same way, kept blowing the fuse and junk.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
