Old 04-03-2010, 08:31 PM   #1
AirSpeed
AirSpeed's Avatar
Installing Windshield
I am getting close to painting my truck and will need to install the windshield. When I had my 69 painted the guy mounted the rubber seal on the windshield and used some small diameter nylon rope in the slot in the rubber to help pull the inner lip over the steel lip in the cab. I was reading an LMC catalog and it recommends installing the rubber seal in the frame then setting the glass into it. Which is the proper way of installing a windshield? Which is easiest? Thanks!
AirSpeed is offline   Reply With Quote
Old 04-03-2010, 09:35 PM   #2
Dark Knight
Dark Knight's Avatar
Re: Installing Windshield
You're supposed to put the rubber on the windshield first, then use the rope to pull the lip over the steel in the cab. Make sure to use lots of silicone spray. I put the top in first because of the 90* corners, then worked my way down. You're going to have to push the rubber onto the lip as you go along. Hope this helps.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 04-03-2010, 09:41 PM   #3
HOGDADDY
HOGDADDY's Avatar
Silicone is a no-no around anything thats gonna be painted and don't even mention it around body shop guys they cringe at the thought of it. But if its already painted then maybe ok but...
Imho use anything but silicone.
HOGDADDY is offline   Reply With Quote
Old 04-03-2010, 10:08 PM   #4
Dark Knight
No, it's not legit silicone in a tube like caulk. It's like WD-40 except it's made to be used on rubber. I would recommend installing the glass after painting though. As long as you have a helper, nothing will get scratched.
Old 04-03-2010, 10:18 PM   #5
HOGDADDY
HOGDADDY's Avatar
I figured that was what you were speaking of and imho I would not use it but ask others for their opinion on paint and silicone spray.
Old 04-03-2010, 10:30 PM   #6
BLT-NT-BOT
I have always used liquid dish soap. dawn, joy or what ever you have.
BLT-NT-BOT is offline   Reply With Quote
Old 04-03-2010, 10:40 PM   #7
69lemans
I've read that in LMC's catalogue,and I think what they mean is to "test fit " the rubber in the frame first,without the windsheild. Then if it fits OK,install the w/s as stated.Some of these aftermarket gaskets don't fit too well and it's better to find out before you install the windsheild
69lemans is offline   Reply With Quote
Old 04-03-2010, 11:20 PM   #8
67/72junkie
I use a piece of small diameter wire that is plastic coated like a cloths line.Have a helper keep light pressure on the outside while you work the rubber seal over the lip from the inside.Take your time and go slow and its not a problem.
67/72junkie is offline   Reply With Quote
Old 04-03-2010, 11:57 PM   #9
GruntMoanCough
GruntMoanCough's Avatar
Yes, HOGDADDY, I am cringing .
No silicone or oil of any type, shape or form, before painting. Soap is good!
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 04-04-2010, 03:07 AM   #10
AirSpeed
AirSpeed's Avatar
Thanks, I must have read it wrong. I won't be putting the glass in until after I paint. Thanks again.
Old 04-04-2010, 03:18 AM   #11
Jeffs70
Jeffs70's Avatar
maybe they mean putting the metal chrome inside the seal first then the glass and then installing it in the truck?
Jeffs70 is offline   Reply With Quote
Old 04-04-2010, 03:31 AM   #12
Diablo de la Noche
Diablo de la Noche's Avatar
I was working on a 60 Corvair on a VERY limited budget. I bought a junkyard windshield and found a new seal. My father-in-law said to use silicon to make the install easier. I squeezed the silicon all on the edges of the windshield seal and proceeded to put the whole thing together. What a mess! I didn't know he meant silicon spray! I won't do that again!
www.coolmoodart.com
Diablo de la Noche is offline   Reply With Quote
Old 04-04-2010, 06:54 AM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I use Goop hand soap for lube. It is thicker and clings in place and doesn't drip off like dish soap.
Old 04-04-2010, 12:54 PM   #14
Jeffs70
Jeffs70's Avatar
concentrated car was shop works great to with out watering it down.
Old 04-04-2010, 01:00 PM   #15
Sillyoldman
#16876
Sillyoldman's Avatar
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 04-04-2010, 06:00 PM   #16
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
As a few have said here, the rubber should be on the glass first and if you have stainless trim, that should go in the rubber before it goes on the windshield. When the "old school" guy installed my winshield he used rope as you suggested. The rope went in the channel, then they set the whole works in the hole. From the inside, he used a small circular motion on the rope to work the rubber over the lip. Every now and again, they would coak the glass in by slapping it with an open hand from the outside. It also works better if the rubber is warm because it softens it up a bit.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 04-04-2010, 06:04 PM   #17
mbgmike
They should know None of their gaskets they sell fit worth a damn
mbgmike is offline   Reply With Quote
Old 04-04-2010, 06:08 PM   #18
mbgmike
Just about anything works to help lubricate the rubber.
No silicone or your fired
not even anywhere around where you will work or paint in the future.
However many people don't realize some auto paint has silicon in it during the Manufacturing but thats a different animal
Old 04-04-2010, 10:32 PM   #19
tim21391
tim21391's Avatar
i agree with hogdaddy.. we have cars come into the body shop i work at right after they are detailed and what not and no matter if you clean the area real good u will have fish eyes in the paint..
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-04-2010, 11:38 PM   #20
gkesseru
gkesseru's Avatar
The absolute best rubber lubricant is available from you local electrician supply outlet. They use is to lubricate electrical cables when pulling them through conduits. Ask for cable lubricant. Also it seems to disappear when it dries without any apparent left-over. Fantastic, no silicone problems and no long-term effects on the rubber either.
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 04-05-2010, 01:02 AM   #21
Jeffs70
Jeffs70's Avatar
Thats a great idea never thought of using that stuff
Old 04-05-2010, 08:27 AM   #22
TomJohnston
TomJohnston's Avatar
Anyone ever use Ruglyde? The detialing forum mentioned it as a cleaner but it is sold as a lubricant. No silicone in it but it does contain some anti-freeze. As long as were here are there any tips on taking a widshield out without beaking it?
Dad's 1970 Chevy C10 Custom
350, auto, armstrong power windows and doorlocks
"My carbon footprint is bigger than yours"
TomJohnston is offline   Reply With Quote
Old 04-05-2010, 08:31 AM   #23
Tx Firefighter
I've used it a lot when installing tires.
Old 04-05-2010, 01:18 PM   #24
67chevemall
67chevemall's Avatar
I lube the heck out of the rubber with motomaster hand cleaner....works everytime.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-05-2010, 07:04 PM   #25
AirSpeed
AirSpeed's Avatar
I have many tubes of "PERSONAL LUBRICANT" (dont ask why I have 24 tubes of the stuff) It is just like wire pulling lube, its water soluble as well, I am going to have to give it a try (on my windshield) and see how it works!
