04 Wind Noise
I've got an 04 1/2 ton Crew cab and the drivers side door leaks air right where it curves at the top. It doesn't do it just driving down the road, but if there is a cross wind (like say driving west with a north wind or driving east with a south wind) it's like it will catch a little lip there and make a terrible noise. I have heard of people rolling the window down and pulling on top of the door to bring it in a little and was wondering if that is about the only thing I can do? It doesn't leak water or anything when I wash it, it's just annoying as all get out. The seal looks to be in good shape and not worn down or anything like that.
All help is appreciated. Thank you, Kevin
1970 Chevy CST/10 1970 Chevy CST/10 1972 Chevy C/10 1972 Chevy Suburban K/10 2019 Silverado 2500 Duramax Kevin |
Re: 04 Wind Noise
I know my truck does the same thing, same area...they replaced the seal and it made the noise less noticeable but its still there and annoying
PROJECT CIRCUIT RIDER |
Re: 04 Wind Noise
Check the back edge of the front door where it meets the rear door, if it sticks out a little adjust the striker in a bit. If the front and rear doors are flush, your only option is to pull the upper door frame in a bit like you mentioned.
It takes quite a bit of force to get them to move. Roll the window down and put you knee in the door panel. Give it a pull from the corner of the frame. Hope this helps. |
S.D.M.F.
Re: 04 Wind Noise
I helped fix one of these at the bodyshop i worked at. the truck was wrecked and obviously we fixed it all and it had annoying wind noise too.
1969 Chevy Longhorn 396/400 3/4 ton. ![]() 1991 Chevy Camaro RS 305/700r4 ![]() 1978 Honda XL175 and XL350(the evil twin) ![]() 2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous 1971 BSA Thunderbolt 650cc ![]() |
