Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 04-07-2010, 08:19 PM   #1
mbgmike
Be cool radiators 73-87 trucks
Manufacturer: BE COOL RADIATORS
Item Category:
Description: Chevrolet & GMC C/K 10 / 20 / 30 Pickup 1973-87
Full-Size Blazer w/o engine oil cooler / Dually / Suburban / Van w/o engine oil cooler 1973-91
# Fitment: A, G, J, S
# Engine: SB/BB
Features: Core Dimensions - Extra Large, 27''wide x 18''high
Overall Dimension - 35''wide x 21''high
Designed for up to 1,000-HP applications.
Drops of 20°-40° after replacing their 4-core copper/brass/lead radiator with Be Cool's industry-leading dual 1'' core radiator. In fact, Be Cool Guarantees a minimum 20° coolant temperature drop or your money back. The all aluminum construction is 25% more effective and 50% lighter than copper/brass/lead radiators. Be Cool features the most effective fin design available today. They also feature the strongest tanks and mounting flanges available. Includes a billet water neck and OEM petcock. Advanced vacuum braised core technology allows Be Cool radiators to offer better temperature control. Epoxy-free construction provides better heat dissipation and allows complete repairability too. Manual transmission applications DO NOT include a built-in transmission cooler, Automatic transmission applications DO include a built-in transmission cooler.
# Best Performance & Value
# Performance Grade Dual One Inch Core
# Epoxy Free Construction
# Billet Filler Neck with High Capacity Over Flow Tube
# Popular Sizes for Today's Applications
# Hand Fabricated Tanks
# Direct Fit Applications
# Down Flows and Cross Flows
# Cross Flow Conversions
# Provisions for Flange, Cradle, Pin and Foot Mounting
# Heavy Duty Automatic Transmission Coolers with Fittings
# Internal Engine Oil Coolers
# Extreme Show Polished Models
# OEM Compatible Fittings & Fan Brackets, Included
# OEM Size Inlets & Outlets
# OEM Style Petcock
# 100% Pressure Tested
# Durable Packaging
# Made in North America
Other: Fitment Codes:
* A: Automatic transmission installation requires (2) of p/n 134-72001
* B: No Blower: 300 Maximum horsepower
* C: Upper & lower hose and transmission line modification necessary to use crossflow upgrade
* D: With passanger-side water pump outlet
* E: With driver-side water pump outlet
* F: Modification required to bottum of core support
* G: Replaces 28-1/2'' core
* H: Uses (4) of p/n 134-72003 to install stock shroud
* I: Some applications require p/n 134-72011 fitting
* J: (1) of p/n 134-72000 needed for installation
* K: Requires drilling for pin foot and flange mounted radiators
* L: (1) p/n 134-72006 & (1) p/n 134-72007 needed for installation
* M: Shroud modification necessary
* N: Uses 66-67 big block radiator hoses
* O: Replaces 34'' core
* P: 2001 & 2002 automatic transmission applications require (2) of p/n 134-72002
* Q: 66-67 Oldsmoblie may require top plate modification
* R: Requires voltage regulator relocation.
* S: Except diesel
* T: Replaces 26'' downflow
* U: Use (2) of p/n 134-72030 to install in 22'' core support
* V: Use 69-76 upper hose
* W: Must use short water pump
* X: For standard shift 4+3 Corvette use p/n 134-62031
* Y: Some applications require p/n 134-72010 fitting.
* Z: 1992-99 Chevrolet & GMC radiator without raised filler neck requires upper brackets: GM p/n 15574275(R) & 15574276(L)
* AA: On all Mopar applications with the XL size core, the transmission cooler is on the same side as the lower radiator hose and it faces outward toward the fender
Characteristics: This radiator is designed for direct replacement of the tall truck radiator. If you aren't sure which one you have, check upper hold down brackets. Narrow, straight brackets are for tall radiators. Narrow ''L'' shaped brackets are for short radiators. To put our radiator in place of tall truck unit, it's a direct fit. To use in place of short truck unit, you must buy upper brackets #14018579LH, #14018580RH and upper fan shroud #15980519. Use old insulators. If replacing Big Block radiator, held in place by a long top sheet metal hold-down cover, replace all insulating rubber with #14063126, four (4) pieces required. You may fabricate mounting insulators if you desire. Don't allow radiator to rub against other parts. Fan shroud may need minor fitting. Use new 12-15 psi GM style radiator cap or Be Cool radiator cap (part #134-70001 or #134-70002 for natural finish or part #134-71001 or #134-71002 for fully polished finish) to professionally complete your installation.
Use (2) 1/4-inch male pipe thread x 5/16-inch female inverted flair fitting (Be Cool part #134-72001). Use Liquid Teflon on fitting to install. Install 1 each in radiator transmission cooler fitting. Install stock lines
$658.00
mbgmike is offline
Closed Thread
