04-08-2010, 10:29 PM | #1 |
widest tire on 15x10
What is the widest tire one can fit on these 71 trucks on a 15x10 rim with stock width axles and lowered 4-5 inches. no spacers.
going to need meat but not going to cut the truck.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
04-09-2010, 12:06 AM | #2 |
Re: widest tire on 15x10
Got a back space for us to work with?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
04-09-2010, 08:10 AM | #3 |
15x10 T'stars with 5.5" BS
04-09-2010, 08:40 AM | #4 |
Is it tubbed? IF not, I think a 11-12" is about as big as you'll get. Tub it like my 68, and the sky's the limit, . I currently have a 12" wheel with a 15.5, but I'm looking to go to a 15" wheel with a 18...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-09-2010, 10:36 AM | #5 |
Redefining LowBudget
hey Rob I thnk we are stuck where we are with the 15.5's that tire will rub on the spring( see your second pic) or the bed..you pick..I have run the #'s and I can't make it work...check the section of the 18's and you'll see...the combo of the added 3" of rim and side wall bubble make it imposable with a stock suspention
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
04-09-2010, 10:37 AM | #6 | |
What kind of back spacing do those 12" wide wheels have? And do your tires tuck into the fender wells? I tubbed my truck too, and I'm thinking while at the track, I need clearance for the tires to tuck on hard launches (plus I'm lowered anyways) I was thinking probably about 8 - 9" backspacing for a 12" wide wheel. |
04-09-2010, 11:22 AM | #7 | |
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-09-2010 at 11:22 AM. |
04-09-2010, 11:27 AM | #8 |
As hard as it will with 100% throttle
04-09-2010, 11:50 AM | #9 |
heres a pic of my tires..this is slammed with a 2 1/2" c notch..these are 31x15.5x15 and I build the truck for 29's so they rub about 1/2" from full dump..my rims are stock rallies with 4" added to the back space ( dumb ass I never measured before I put them on) when I switch to radials it will all clear fine...my tubs are 4" wider..if you look at the stock tub I moved it one hole to the center
04-10-2010, 02:13 PM | #10 |
Wondering if 325/50 DRs will work....
Tire Diameter 28.00 in. Section Width 13.10 in. Tread Width 11.60 in
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap Last edited by Shon; 04-10-2010 at 04:23 PM. |
04-11-2010, 08:43 AM | #11 |
your going to have to pick a tire size and build the truck around that..in other words how low and wide you want it to look..also if you you find an older (pre70) rear axle you will end up with a little narrower trac which will help with rubbing
maybe you need to take some measurements from what you have then we can GUESS on a choice
04-11-2010, 08:48 AM | #12 |
I will just pick a tire that will fit and make it work.
only reason I mentioned the 325/50 is b/c a buddy had 2 sets i can use.
04-11-2010, 09:01 AM | #13 |
then I would grab one lift you truck up ( by the axle) take your wheel off and see how it looks and fits......since your not going to tub you can get a good idea and rotate your tires at the same time..???
04-11-2010, 09:10 AM | #14 |
My Carbon Footprint
One thing that doesn't look like it's been mentioned is that certain width tired are designed to go on certain minimum width wheels. Just because the tire machine will get it on doesn't mean it's right or safe. In a perfect world, you want the edge of the tire tread to be parallel with the edge of the wheel. If you have a 12" tread width and a 15" center section on a 10" wheel. That is not good. Changes how the bead of the tire meets the wheel. really hard on the sidewall too and it will start to crack over time. Just a thought.
04-11-2010, 11:59 AM | #15 |
^^^^ Good point^^^^
04-11-2010, 12:49 PM | #16 |
Truck and auto performance nut
all true with todays lower profile tires. with a taller profile (70 up) you can get away with a wider tire/narrower wheel scenario...but not by much.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-11-2010, 04:25 PM | #17 |
325-50's are a common size used on 10" wheels.
04-11-2010, 05:10 PM | #18 |
these tires do fit on the 10" rears per Manfucturer's rec but do they fit a 71 in stock form with T'star 5.5" BS
04-11-2010, 06:10 PM | #19 |
5-5.50" back-spacing is common to 71-87's for a 10" wheel. You need to measure your truck to be certain they'll fit. What fits one may not fit another; always verify your set-up.
What is currently on the truck?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-11-2010 at 06:11 PM. |
04-11-2010, 06:35 PM | #20 |
I have ran the 315/60's on 2 trucks. I used a 15x10 wheel with 5 inch backspacing both times.
72 LWB |
04-11-2010, 06:36 PM | #21 |
71 lwb
04-11-2010, 08:28 PM | #22 |
At the body shop.
hoosier d/r 325/50 on 10 doing work.
04-11-2010, 10:44 PM | #23 |
currently using BFG 275/50/15 on 15x10 rally, this tire is not going to work with what I got planned, I am going to need more meat!
04-12-2010, 06:44 AM | #24 | |
I'll bite What are you planning???
04-12-2010, 07:32 AM | #25 |
right now with no suspension mods and the 26" BFG DRs it doesnt like to be hit out the hole with the 100 shot, I can hit it about 30-40' out and it is fine so I will be going to 28" tall tires for looks and to get more meat and I hope to eventually put 150-200 shot from a Nitrous Outlet Plate system. And while doing all of this it will eventually have heads and cam plus a GOOD stall TC (yank or vig/PI). If I follow the recipe of the others cars I have been involved in, I should be able to make 475-500 to the wheels on motor.
