Old 04-14-2010, 10:06 AM   #1
53lochevy
53lochevy's Avatar
53 airbags/shocks mounted and wheel tubs/notched
Here's some pics of the bags and shocks installed over axle configuration... The wheel housing come from 65-72 chevy trucks and has bolt holes on both the outside flanges and the bottom flanges.. The center bolt hole for the fender lines up with the center hole in the wheel housing..also installed bumper stops on the other side of the frame for when the air is out and not just laying on the bags....also cut out the radius for the tire...Let me know what ya think about the tubs.. they are big but going center over axle configuration with a 4-link its gotta cover it and also can go to 50's tires later if wanted..
53lochevy is offline   Reply With Quote
Old 04-14-2010, 10:15 AM   #2
53lochevy
53lochevy's Avatar
Re: 53 airbags/shocks mounted and wheel tubs/notched
more pics
Old 04-14-2010, 10:56 AM   #3
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Looking good, are you going to keep the tubs that wide?
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 04-14-2010, 11:02 AM   #4
53lochevy
53lochevy's Avatar
Yes the upper bag mounts and the air line wont fit under the bed without them when going with over axle configuration,, the bed is going to be raised just one inch....so the rearend will not go thru the bed.. heres a pic hows it sits with the air out..
Old 04-14-2010, 11:02 AM   #5
britnjc
britnjc's Avatar
How about trailer fenders as tubs, they come in different widths and have a smoother design. not a thing wrong with what you got just another option
britnjc is offline   Reply With Quote
Old 04-14-2010, 12:31 PM   #6
1952ssr
1952ssr's Avatar
I was gonna mention the same idea. You can pick up the ones with one side enclosed at any Tractor Supply or at Northern tool.com. Here's an example. OBTW your truck looks great.
1952ssr is offline   Reply With Quote
Old 04-14-2010, 01:16 PM   #7
53lochevy
53lochevy's Avatar
The picture listed is not the orginal frame probably a as-10 and it is not configured with over the axle airbags.. I'm using the orignal frame with c-notches and over the axle airbags,,, with the notch and bracket on it is 11 inches from the side of the bed to the outer of the bottom of the bag bracket,, didnt want to run a bar all the way across the bed and mount different bag configuration and shock combo let alone didnt want to have to raise the bed to fit it...hope that kinda fill ya in on the reason I have to have wide tubs because of the over axle configuration actually it looks good when standing and looking into the bed,, going with a solid sheet to wood 4+8 and cutting it to fit and just lay it in there..Just going one inch where the side bed supports are spot welded to the side fenders lay it on top of that and get new side strips and lay the rest on top use the cross frames as drill guides..
Old 04-14-2010, 11:08 PM   #8
ratty 46
Clean & I understand the reason for the inner tubs. I think a more "rounded" set might look more 53ish if you get my idea .... but all in all - very functional.
Nice job.
Ratty 46
ratty 46 is offline   Reply With Quote
Old 04-15-2010, 02:25 PM   #9
mylow53
mylow53's Avatar
i've seen guys use those tubs before they just cut an inch or 2 from the middle. seeings how your tire will never pass your frame you could probably take out a bunch from the middle. provided your air bags cleared. my suspension is similar to yours but the bags are underneath the bed. you may consider relocating them to clear up some bed space. my tubs are much smaller due to the airbag placement granted you noch is huge compaired to mine. you should be able to go much lower than me.
your truck is pretty cool
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 04-15-2010, 02:48 PM   #10
53lochevy
53lochevy's Avatar
GT
Again look at the pics this is over center axle airbag configuration not in front under the axle as you have with a trinangular link setup not a 4-link as I do go figure Im running tight wheel clearence with about 1/2 inch space on the outer fender and 1 inch inside the inner fender on the bed about 12inch tire width I really dont care about bed space as I will never carry anything back there but a cooler for drinks................
