Old 04-14-2010, 05:25 PM   #1
'87Silverado
Exhaust System
Hey guys, I've got an '87 TBI Silverado and am looking at doing a new exhaust system. I've been looking at a set of long-tube headers that are ceramic coated from Summit Racing.
I know I'm going to have to go to a 3-wire (heated) o2 sensor, but my question is the placement of the sensor. I found some collector reducers with the o2 bung already installed, which seems preferable than trying to weld one into the header collector itself. Will this be too far away from the exhaust ports to put the o2 sensor or will it be ok since I'm going with a heated sensor? Thanks for the help.
'87Silverado is offline   Reply With Quote
Old 04-14-2010, 09:36 PM   #2
USSkoval
Re: Exhaust System
When I did mine, I bought reducers with the bung in them, but later decided not to use them. I drilled a hole in the driver side collector and welded in a bung, it has worked very well and was easy. I ran the stock o2 sensor for a few years, then just recently went with a heated sensor. Cold starts have improved a little, and mileage is just a bit better, but it still ran well before.
USSkoval is offline   Reply With Quote
Old 04-14-2010, 09:50 PM   #3
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
Re: Exhaust System
I would do it on the collector, dont the camaro headers already have an o2 sensor in them? I know alot of guys have been using them on the trucks to have more clearance.
staggerd86c-10 is offline   Reply With Quote
Old 04-14-2010, 10:18 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Exhaust System
Yea mine were already on and in the collector and work just fine. Already had the 3 wire setup on it work just fine!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-15-2010, 10:17 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Exhaust System
Chevelle headers fit great! I use 3/4 length headers on my truck.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-15-2010, 04:46 PM   #6
'87Silverado
Re: Exhaust System
Chevelle headers for the '68-72 models? What model Camaro headers fit? The one's I found on Summit are like $220 and they are ceramic coated (that's the only reason I'm asking about getting the collector reducers with the bung as I'm not sure how it would work to drill a hole and weld the bung in the header collector's themselves.) Thanks for the help guys.
Old 11-02-2010, 08:12 PM   #7
carloscanales
Re: Exhaust System
hey gchemist do you habe any part numbers??? what brand are those?? ceramic coated?? any issues fitment?
i think those are what i need for my truck
carloscanales is offline   Reply With Quote
Old 11-03-2010, 01:17 AM   #8
gchemist
gchemist's Avatar
Re: Exhaust System
Sorry I don't have a part number. I bought them off ebay. Yes they are ceramic coated. No fit issues. The starter is a little close. The driver side does stick down a little.
Install pictures
Old 11-03-2010, 11:14 AM   #9
rfmaster
rfmaster's Avatar
Re: Exhaust System
If you are using a heated O2 sensor you can place it down stream from collector flange (within coupe of inches). It works well - just make sure that O2 tip points down (about 15 deg would do) - this will allow moisture to drip down and not contaminate O2 sensor.
Yes, whats the part numbers (or model years ) of them headers???
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 11-03-2010, 08:40 PM   #10
gchemist
gchemist's Avatar
Re: Exhaust System
Any 70's Chevelle will work.
