Old 02-06-2001, 09:01 PM   #1
69fine
Post POWER STEERING CONVERSION
I have a 69c-10 with a big block 4-speed.
Want to add power steering, want to know what is needed to make the change? I have the pump , want to of a company that sell a
good system, or what's needed if I go donor
parts? thanks in advance for any help.
69fine is offline   Reply With Quote
Old 02-06-2001, 10:39 PM   #2
ImpalaSS
Post
so you have the pump and brackets? well the gearbox from a 68-81 will work (just make sure its a gearbox from before they switched to metric)
www.xframeimpala.com
68 4x4 short fleetside deluxe cab 327 air
56 big window short stepside
64ImpalaSS 327 700R4
67 1 ton dually 157" wheelbase 327 SM420
ImpalaSS is offline   Reply With Quote
Old 02-07-2001, 02:34 AM   #3
C.Jackson
Post
if you find a box from a 68-up make sure it is the 2wd indexable variety. the 4wd looks identical with exception to mounting the pitman arm to swing front to back instead side to side. there is no choice in the matter and it won't work with your 2wd.
C.Jackson
Juneau, Alaska
'81 crew cab dually..5 ton gear, air, 10sp, 3208..if it aint a CAT it must be a dog
'87 K-5..454..9"..38.5's (the wife's)
'72 C-10..427 tall..FAST (the wife's)
'49 Dodge 5 window..413 max wedge..VERY FAST
'79 Dodge one ton..440..15"..38.5's
'84 S-10..350 auto (the wife's)
C.Jackson
Juneau, Alaska
Dba AC-DC Electrical and Equipment Repair
C.Jackson is offline   Reply With Quote
Old 02-07-2001, 01:39 PM   #4
ImpalaSS
Post
if you find a 4x4 one get it anyway... sell it there worth a good amount of $
Old 02-07-2001, 09:26 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Post
If you go donor,
You need the 2WD pump, the pressure and return hose and the pitman arm.
http://www.agrsteering.com sells rebuilt boxes for around $300. You still need the other pieces though.
Chris Lucas
1973 Chevy C-10
1975 Chevy Silverado
Captkaos' Page
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
