04-15-2010, 10:25 PM | #1 |
Lift Blocks ?
I have a '71 4x4 burb, and I wanted to do a mild lift...like 2 inches, but I dont wanna do a body lift. Is there any lift blocks I could use on front and back to raise it a bit?
04-15-2010, 11:43 PM | #2 |
Re: Lift Blocks ?
Do a body lift before front lift blocks.
Any reason not wanting to do a body lift? IT is safer than frnt lift blocks. The cheapest way is to make longer shackles for the front and lift blocks in the rear. The best way would be to buy the front springs and either get new spring for the rear to or use lift blocks on the back.
72 gmc 2500 2wd drive convert My 72 thread http://67-72chevytrucks.com/vboard/s...d.php?t=346712 THe other truck, wheeler 69 1/2 4x4, yellow and rusty. http://67-72chevytrucks.com/vboard/s...d.php?t=350300 Last edited by onlyifihadachevy; 04-15-2010 at 11:47 PM. |
04-16-2010, 12:09 AM | #3 |
SWB 4x4 Collector
Re: Lift Blocks ?
I think Rancho used to make a 2 1/2" lift for our trucks. You may contact Randy (Teeitup) as I believe he has that lift on his 67' 4x4. I don't know if they still carry it or not. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
04-16-2010, 05:48 PM | #4 | ||
"I ain't nobody, dork."
Re: Lift Blocks ?
Blocks on the front are a no-no... lift springs aren't all that expensive for the front.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
04-16-2010, 05:54 PM | #5 |
20' Daredevil (Ret)
Re: Lift Blocks ?
Another NO vote for blocks in the front... and frankly, I've never been a fan of longer shackles either.
Skyjacker also makes 2 1/2" Softride front springs.
04-16-2010, 06:23 PM | #6 |
Re: Lift Blocks ?
04-16-2010, 06:58 PM | #7 |
20' Daredevil (Ret)
Re: Lift Blocks ?
To clarify... I grew up in the Sixties, and a lot of kids used shackles to lift the rear of their cars. Aside from poor structural strength (which I never thought about at the time), it seemed like the springs would begin to sag after the shackles were installed.
04-16-2010, 08:50 PM | #8 |
Re: Lift Blocks ?
You can use what is called a zero rate block. It is an "add-a-leaf" that doesn't change the spring rate. It bolts into the leaf pack using a longer center bolt. Most are 1" and you could do a 1" longer shackle which would net you 1 1/2" lift.
04-17-2010, 09:01 PM | #9 |
Chevys Kick A$$
Re: Lift Blocks ?
Yea same here. Atleast don't do blocks in the front! Longer shackles will work but I don't think they are the best either lol!
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
04-17-2010, 10:11 PM | #10 |
Re: Lift Blocks ?
Front lift blocks... BAD
Longer shackles... eh, they're OK "Zero Rate"... good option, but still add leverage to the stock spring Body lift... not a fan unless you need a little more lift on top of an already big lift ...Just get front lift springs |
04-18-2010, 05:19 PM | #11 |
Devil's in the Details
Re: Lift Blocks ?
What he said.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
