04-21-2010, 03:52 PM | #1 |
69' Chevy Stepside
1969 C10 Disc Brake Conversion, Only Front Brakes will Work???
While restoring my 69' C10 which originally had manual 4 drum brakes, I converted the front brakes to disc brakes, new calipers, rotors, pads, and hoses. I bought a new master cyl from Car Quest for a 72 Chevy with factory front disc brakes. Then I got a proportioning valve from CPP. Before installing the master cyl I bench bleed it very good so that no bubbles were coming out. After plumbing new lines from the new master cyl to the proportioning valve, I bleed all the brakes starting with the passenger rear, drivers rear, moved my way up to the front passenger side and driver side. So after pressure bleeding them, I only had front brakes. So I gravity bled them and slide the prop valve back to center and tried them again. Same thing instant only front brakes. Its been this way for the last year. I've gone thu like a gallon of brake fluid or more just in bleeding these things so I'm almost 110% sure theres no air in the lines. Brake pedal is also hard, but when I slide the prop valve back to center and jamb something in there to keep it centered they feel great just like normal. But it always slides back over and blocks off the rear brakes???
I have access to an original working master cyl and original factory proportioning valve from a 72 Cheyenne should I swap this on there and see if it fixes it? So what could cause this? Bad master cyl? Bad proportioning valve?? Or?
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 04-21-2010 at 04:02 PM. |
04-21-2010, 04:05 PM | #2 |
Re: 1969 C10 Disc Brake Conversion, Only Front Brakes will Work???
Have you called CPP or e-mailed Jeff from CPP who's on here quite frequently? I don't think that prop valve is supposed to block the rear brakes under normal circumstances. I believe that's a safety device intended to cut off a section of the brakes if a massive leak occurs so as to preserve at least half your brakes. Might be a defective prop valve.
04-21-2010, 04:10 PM | #3 | |
69' Chevy Stepside
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
04-21-2010, 04:22 PM | #4 |
the one thing i noticed you did wrong was the driver rear is the furthest away and should b bleed first
04-21-2010, 07:33 PM | #5 |
Watch out for your cornhole !
Are the rear brakes adjusted up nice and tight ? If they are too loosely adjusted, the volume of fluid that is needed to push them out against the drum can trigger the prop valve by mimicking a rear brake failure which would cause the issue you're having.
04-21-2010, 07:51 PM | #6 | |
69' Chevy Stepside
04-21-2010, 09:46 PM | #7 | |
69' Chevy Stepside
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 04-22-2010 at 12:35 AM. |
04-21-2010, 11:14 PM | #8 |
"Trucks with Class"
Like you said...try another one and eliminate that area.
04-23-2010, 12:16 AM | #9 |
69' Chevy Stepside
Bump, any other ideas?
05-07-2013, 01:28 PM | #10 |
swap out the valve... process of elimination.
05-07-2013, 01:31 PM | #11 |
I figure he has found a solution. The thread has been dormant for three years.
Posted via Mobile Device |
05-07-2013, 01:45 PM | #12 |
I would hope so but he said it was previously like that for a year before he tried fixing it and seems like he didn't want to swap out the valve, would like to know what he did about it just in case I ever have this problem.
05-07-2013, 01:51 PM | #13 |
That's one of the bad parts about boards like this. A lot of guys never follow up with final outcomes. We are sometimes just left wondering what the answer came out to be.
05-07-2013, 10:06 PM | #14 |
69' Chevy Stepside
Glad someone bumped the thread totally forgot about it. I ended up replacing the proportioning valve with a new one and it solved all of my problems. The CPP one must have had something bad inside of it. After the change I rebleed the brakes and everything works perfectly just like it should! Sorry I never followed up.
05-07-2013, 11:32 PM | #15 |
Cool, thanks for the follow up. Will be that much easier if this problem comes up.
