04-22-2010, 12:24 PM | #1 |
1 3/4" LS swap headers
I bought an LQ4 - so it's time for an exhaust change from the standard SBC Thorley Tri-Y's...
Do 1 3/4" LS swap headers exist? Any alternatives??? Thanks |
04-22-2010, 01:28 PM | #2 |
Re: 1 3/4" LS swap headers
I've looked around for my swap and all I've seen are shorties. Even if they were available in 1 3/4 I'm not going to bother since shorties don't offer much advantage over the stock manifolds.
I really want long tubes for my swap, so for now I'm going with a pair of vette manifolds I picked up for cheap, they flow a bit better than the standard LS truck/pass car manifolds do, and I think I can make them work. Maybe later down the road when someone comes out with a longtube swap header I'll switch over. |
04-22-2010, 03:44 PM | #3 |
I can't remember what size mine are, but I have LS1 F-body headers (stainless steel) and they fit like a glove. and are tucked up pretty tight. (Especially compared to most gen 1 sbc longtube headers)
http://cgi.ebay.com/ebaymotors/LS1-F...Q5fAccessories
Project Bruiser: 68 Pro-Touring C-10 5.3L / 4L60E Project Ironhide: 97 GMC Crew Cab 4x4 Cummins SOLD: '69 GMC 1/2T SWB TBI'd: Project No Buck Assembly Manual Index Sign up Thread!!! Factory Service Manual Index Last edited by Ackattack; 04-22-2010 at 05:30 PM. |
04-22-2010, 04:55 PM | #4 |
On the fast track to nowhere..
I bought stainless F body long tubes for mine. Off brad but seem OK to me, especially for the price. The coating could be better. They have the emissions connections I have to get rid of but that should be easy enough. I'll check the primary size tonight.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
04-22-2010, 05:07 PM | #5 |
Awesome -- I'm finding 60's camaro LS swap headers in 1 3/4 that supposedly work with mechanical clutch linkage, so if I can't get a definitive answer from you guys, I might have to roll the dice on 1st gen camaro headers.
Thanks for checking into it. Last edited by Jim_PA; 04-22-2010 at 05:08 PM. |
04-22-2010, 05:25 PM | #6 |
04-22-2010, 05:38 PM | #7 | |
Wonder if they have a return policy Nice price too. |
04-22-2010, 07:44 PM | #8 |
Trucks N Tranzams
I thought you were building a 383?
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
04-22-2010, 08:40 PM | #9 |
I got cold feet. Realized that build would be maxed out on day 1, and that's not how I roll . That, and it was getting very expensive for "just another small block"
04-22-2010, 09:51 PM | #10 |
Well, the ones I bought are linked below. I looked and didn't see where he's still selling them. The pic on the auction shows 1 3/4, mine actually measure 1/16 short of that. Slip fit 3" collector, 3/8 flange and they're stainless. Maybe you could contact him if you're interested and see if he still has some. My frame isn't anywhere near stock so it's hard to compare but other than a tube on the drivers side contacting the washer on the 73-up arm they fit great. If it wasn't for the 1.25" crossmember section I did they wouldn't even touch. And, they were only 190.00!
http://cgi.ebay.com/ebaymotors/ws/eB...m=180463098193
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting Last edited by BACKYARD88; 04-22-2010 at 09:53 PM. |
04-22-2010, 09:55 PM | #11 |
wouldnt be a bad deal if it didnt have that egr ****
04-22-2010, 11:09 PM | #12 |
Those don't look too bad for the $
04-23-2010, 08:48 AM | #13 |
There are 3 tubes with flanges, I plan to cut them off and weld a cap on them. I'm sure they could also be threaded and a plug screwed in. Can't beat them for the money though.
04-23-2010, 09:54 PM | #14 |
Trucks N Tranzams
I can appreciate this. I have almost 5k in my 383, $1500 in my TH400 and another $1500 in my gear vendors overdrive. I could have built a solid 6.0/4L80 for this money and it would be fuel injected. I have a 650 Demon for carburation. It really runs, but I know I could have done better.
04-23-2010, 11:40 PM | #15 | |
04-24-2010, 11:19 PM | #16 |
Andy
All you need is a cam, headers and a ls6 intake on the 6.0 and you'll be making 450 hp.....easy. With the headers and the stock truck intake you sould be a solid 400 hp. I installed a set of headers on a 98 trans am that backyard88 mentioned in his post. I was amazed at the quality considering the cost. Definitely worth the money.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi 1969 CST/10 383|Aisin AR5 5 speed 1972 K5 350|Turbo 350 4x4 2005 Duramax 2500HD 4x4 |
04-24-2010, 11:44 PM | #17 |
Truck and auto performance nut
If your considering going to the L92/LS3 heads...you may want to look at some with 1 7/8" primaries. The thinking for some is the intake side of those heads flow so well (330cfm @ .600 lift?) yet the exhaust side doesn't quite match the flow, so it needs a little help... like more lift, more duration, and/or a larger primary. I've been trying to get a set of the DT's made in 1 7/8" since they are built and finished well, and their swap headers are made for our (67-72) trucks...plus they don't hang down below the frame rails and tuck nicely.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
04-25-2010, 07:46 AM | #18 |
Ok, Good. it's looking like I'll do a t56 and hydraulic clutch in this at the same time, just have to find a complete pull out
05-19-2010, 09:15 AM | #19 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
