04-24-2010, 02:32 PM | #1 |
Best Rust Penetrator?
I,m about to do some tear down and was wondering what everyone recommends to loosen rusty bolts before i break them and my knuckles. WD 40 seems to be most popular but Ive seen everything from 3 to 12 a can
04-24-2010, 02:44 PM | #2 |
Re: Best Rust Penetrator?
a 3foot extension on the rachet works wonders// a torch is great//a spray bottle filler with vinegar(about $3 a gallon) works good// sometimes the most effective is to turn the wrenches clockwise and just snap the bolts
04-24-2010, 02:50 PM | #3 |
pb parts blaster
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
04-24-2010, 03:04 PM | #4 |
Six in a row makes it go...
I've had good luck with this - especially if you can let it soak a good long time...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
04-24-2010, 03:47 PM | #5 |
There was a big thread on this about two months ago. Let me see if I can find it.
Here is the thread: http://67-72chevytrucks.com/vboard/s....php?p=3898937
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. Last edited by 71swb4x4; 04-24-2010 at 03:51 PM. |
04-24-2010, 03:49 PM | #6 | |
I am NOT a fan of WD-40 as a penetrating oil, PB Blaster is far better.
cdowns has a point though about breaking them though, as long as it's a bolt/nut situation, it works well.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
04-24-2010, 04:33 PM | #7 |
p blaster is the **** !!!!!!
04-24-2010, 04:58 PM | #8 |
There was a showdown of products a while back I saw on the net about penetrating oils. The winner was actually a mix of 50% acetone and 50% ATF. Worked better than PB Blaster and Aerokroil (sp?)
04-24-2010, 04:59 PM | #9 |
The Older Generation
I read one time that GM sells the best stuff for this. The kicker is that it sells for about 8 bucks a can.... LockDoc
04-24-2010, 05:06 PM | #10 |
if people would just b openminded enough to use good old vinegar at about $3 a gallon they wouldnt b spending $30-$80 a gallon on stuff that is marginal at best
04-24-2010, 05:13 PM | #11 |
apple? or rice?
I still just use PB blaster. |
04-24-2010, 05:24 PM | #12 |
Active Member
I've tried them all except the vinegar. I've found out that none seem to be superior to the other on extremely rusted nuts and bolts.
The idea of breaking them is okay on the smaller bolts where you can do it without ruining any sheet metal. It's a bit harder to do and probably not a good idea if the bolt has a welded nut- as in the fenders/wheel wells. Lately I've been using diesel fuel sometimes mixed it with a slight amount of either oil or trans fluid. I put in a spray bottle and for what it's worth, has worked just as well as the others. |
04-24-2010, 05:36 PM | #13 |
PB rust penetrator is the best I've seen.
Let it soak, &/or use heat before trying to break loose. With aluminum motorcycles etc. Sometimes you can just give it a "bump" in the tighten direction then snap back to loose mode. I'm sure like everything else. You'll get it. Used it on a lot of Vintage motorcycle restoration work, and of course my ole' 72 raised in Utah. (salt roads) Theres also acids for large jobs but california epa took most of the good stuff. |
04-24-2010, 05:54 PM | #14 |
Shake and Bake!
PB gets er done, at least in my experiences. Although I will have to try that vinegar trick Cdowns.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
04-24-2010, 06:02 PM | #15 |
me i just get the generic cheapo stuff
for the master blaster crew who dont believe just go into your junk boxes take 2handfulls of rusty crap put each into a container fill one with 30cents of vinegar the other with 5or6bucks of pbblaster let set overnight then see what works
04-24-2010, 07:17 PM | #16 |
Gone to greener pastures
Heat and candle wax.
Get your wrench all set to go; heat the bolt with a propane torch, then hit it with a candle. Put the wrench on & screw the bolt out.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
04-24-2010, 07:41 PM | #17 |
I'm interested in this vinegar trick. Are you just putting straight vinegar in a spray bottle then spraying the bolts? Do you let it sit a while?
04-24-2010, 07:44 PM | #18 |
I can vouch for the vinegar trick. I just poured 2 gallons in a bowl and put some old rust 72 parts in it for about a week. Took them out and they look new. I just washed them off and primed. Amazing.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
04-24-2010, 07:54 PM | #19 |
The best is aero kroil you can get it usually at you local catapiller dealer along with the best grade bolts money can buy.Kroil is a step above anything you've ever used and won't let you down.
04-24-2010, 11:38 PM | #20 |
I like the CRC brand of penetrating oil.
04-24-2010, 11:52 PM | #21 |
Registered Chevy Owner
I'm going to try the vinegar trick.
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
04-25-2010, 12:30 AM | #22 |
Devil's in the Details
I exclusively use Kroil myself, but I've only ever heard good things about PB Blaster too.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
04-25-2010, 01:03 AM | #23 |
Location: Aurora,Il ..born,raised and still live in the same house
My dad was a big fan of "tightening" the bolt just a hair, then it would loosen. It works especially well on screw heads.
I used to be a fan of WD 40 until i got a can of PB Blaster. that stuff is amazing. now it's all i use. |
04-25-2010, 09:40 AM | #24 |
My favorite spray is In-Force from BG Products. Its expensive but it really works. It foams.
The best thing was posted earlier. Canning Wax & a Torch!!
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
04-25-2010, 09:53 AM | #25 |
Yeah the vinegar trick has been used for years nothing real new. Most of the chemical companies I have worked for have been mixing up their own version for years cause it cheap.
