Old 02-21-2001, 07:13 PM   #1
Silverado6.6
Talking It has started.......
Well, first off, I'd like to thank you all for responding to my first post "why isn't my truck starting?!" well, I traced the problem all the way down to the high quality auto zone unit that I had.....it was "new" and had not been on anything, I took it right out of the box, and bolted it up...well, needless to say, i went back to AZ, and got yet another "new" starter and bolted it up and it spun over....I was quite happy....after discovering I had my distributor in 180 degrees off, and swapped over all my spark plug wires...I got it to start up, and ran it for about 6-7 minutes...while adjusting rockers and such, I went back up today to get some more work done on it....and drove it around the lot a little bit, it feels like it'll be kinda peppy, time will tell....anyways, I have one more question, the vacuum line that goes from my tranny (TH400) to the ???? I've got an edelbrock #1406 600 cfm w/ elec choke on top of the stock cast iron manifold....where do I put this vac. line?? does it go to the front of back of the carb, or what? if I can get all these little things taken care of, I should be driving it by friday....thanks again
'81 3/4 ton Silverado Warmed up 355
TH400 w/shift kit
Corporate 14 bolt w/ 3.73s
94 S10
82 K30
81 C20
80 K20
76 C10
69 C20
68 C10 4 sale
51 3600
Silverado6.6 is offline   Reply With Quote
Old 02-22-2001, 02:15 AM   #2
bigd65
bigd65's Avatar
Post
you should have a vacuum port on the manifold behind the carb, that is where it hooks. if not then just hook it to any manifold vacuum sorce. if it is a stock cast iron manifold it should have the port on the manifold or a place you can screw one in. good luck.
85 C10 350/700r4
HOLLEY STREET DOMINATOR IANTAKE
EDELBROCK 1406 COMP. SERIES CARB.
HYPERTECH POWER COIL
FACTORY HEADERS
MAGNAFLOW CAT/MUFFLER/3in. EXHAUST
3.42 REAR GEARS
PROTHANE SUSPENSION-TOTAL KIT
and still going
"thats my toy"
Jeff Dodson
Angleton,Tx.
2004 Silverado Crewcab (Dark Spiral Gray)
bigd65 is offline   Reply With Quote
Old 02-22-2001, 02:20 AM   #3
t korinek
Truckin' Krazy
t korinek's Avatar
Post
The line just runs straight to manifold vaccum, usually to the port coming right out of the manifold behind the carb.
Dealer for:
American Auto Wire
Precision weatherstripping
Dakota Digital
Trim parts Carpets
Truck World seat covers
& Many others
Chevy Parts locator in Mesa AZ!
t korinek is offline   Reply With Quote
