Old 04-25-2010, 09:49 PM   #1
sider68
sider68's Avatar
Door Weatherstripping
I have door weatherstripping for 56 chev pick up. There were no instructions. Any tips? Whre should the joint be? Do I need any silicone?
sider68 is offline   Reply With Quote
Old 04-26-2010, 07:33 AM   #2
bondobob
bondobob's Avatar
Re: Door Weatherstripping
The joint goes at the bottom of the door. I've read posts that recommend taping it on with painters tape and close the doors for a week to pre squash the gasket. One guy used a ratchet strap between the doors to pull them in. GENTLY!!! Some brands are tighter than others.
bondobob is offline   Reply With Quote
Old 04-26-2010, 04:44 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
There should be a screw on lip that holds the bottom in place. Its about 24" long. There is also a clip near the door handle to clip that part into place. The rubber should snap into place without a whole lot of trouble unless you got the rubber without the pegs.
dwcsr is offline   Reply With Quote
Old 04-26-2010, 06:09 PM   #4
blackdiesel
blackdiesel's Avatar
No silicone, 3-m super weather stripe adhesive, (get it in black not yellow) if you didn't get the rubber with the pegs.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 04-26-2010, 07:11 PM   #5
OrrieG
OrrieG's Avatar
Mine, original never touched until I removed it, had the clips shown below at the corners and two up higher. If there was any kind of bar at the bottom it was completely rusted away or had been taken off. Steal your wifes clothespins or use binder clips to hold it in place while the snot dries.
OrrieG is offline   Reply With Quote
Old 04-26-2010, 09:38 PM   #6
entourageguy
Yellow truck club
entourageguy's Avatar
Orrie your stripping looks barely broken in ....
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
