Old 04-25-2010, 10:39 PM   #1
onesmokinduramax
Help how 2 tell from dana 60 and dana 44
Ok im going to look at a axel tomro all i know its from a 3/4 ton chevy truck how can i tell if its a dana 60? can and one post a few pic im going in the moring to look at it so i need to know for sure if its a 60 and not a 44. its still on the truck and i would hate to spend the money and end up with just a 44. can some one help me out here.
04 Chevy Duramax LLY crewcab 4X4
Built ATS Allison Upgrades making around 500HP!
75 chevy 3/4 ton 4x4 its got a built 350 with dana 44 and a lift.
onesmokinduramax is offline   Reply With Quote
Old 04-25-2010, 10:51 PM   #2
onlyifihadachevy
Re: Help how 2 tell from dana 60 and dana 44
IF it is a dana 60 it will have d60 cast into it, near the inspection cover. And it will have 4 bolts holding the steering arm.
The d44's only have 3 bolts holding it.
If it is 3/4 it will be a d44.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 04-25-2010, 10:56 PM   #3
onesmokinduramax
would u happin have a pic the guy said it dont have no #s on it so i dont know if he just not lookin right or what and also he said he thinks its a 3/4ton but could be one ton i just hate make the drive not know what look for
Old 04-25-2010, 10:57 PM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here is how the passenger side spring is attached - the two bolts you see here, or two studs rather than a u-bolt on the inner side is an easy way to determine if it is a Dana 60.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-25-2010, 11:28 PM   #5
onesmokinduramax
Yukon hey thanks for the pic thats what i thought it would look like but wanted to make sure. thanks again
Old 04-25-2010, 11:38 PM   #6
b454rat
No numbers probly means a 10 bolt.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 04-26-2010, 12:09 AM   #7
onesmokinduramax
ok lol kinda new to all this stuff is a 10 bolt mean a dana 44 or 60?
Old 04-26-2010, 12:31 AM   #8
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
No, 10 bolts are different than a Dana axle. Here take a look at this link. It should help you out on identifying the different axles.
http://coloradok5.com/axleguide.shtml
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 04-26-2010, 12:37 AM   #9
Beelzeburb
Devil's in the Details
Beelzeburb's Avatar
"Axel tomro", is that some sort of band you kids are listening to nowadays?
If it really is a 3/4 ton truck and the front axle has never been replaced, then it will not be a Dana 60.
This guide might help a bit:
Here's more info than you ever wanted to know about a Dana 60 front axle:
http://www.pirate4x4.com/tech/billavista/60_front/
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread
Datsun 240Z, 510 2 door and an old Honda motorcycle
Beelzeburb is offline   Reply With Quote
Old 04-28-2010, 09:18 AM   #10
msgross
msgross's Avatar
only K-30's had dana 60's, you will find most of them in early-mid 80's K-30's. There are two different options though, SRW and DRW (single rear wheel and double). You want to hold out for a SRW since it will cost you more money to convert a DRW. Prices are usually around $800+. You can find a 10 bolt or dana44 for under $150 complete.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-28-2010, 09:22 PM   #11
Big-Blue
Big-Blue's Avatar
This is a Dana 60. Note the 60 at the lower right. It's kind of hard to see.
Big-Blue is offline   Reply With Quote
Old 04-30-2010, 11:01 PM   #12
Jason M
Any Chevy 60 will have King Pins instead of ball joints. That's about the quickest way to spot one. But as posted earlyer in thread no 3/4 ton chevy will use a 60 front, unless it was swapped there.
Only Dodge and the 78/79 Ford used the 60 front in the 3/4 ton trucks. But they were special package trucks like camper special or a snow fighter.
Jason.
Jason M is offline   Reply With Quote
