2006 GMC Air-conditioning question?
I just bought a 2006 GMC 2500 Duramax CrewCab 4x4, it has dual zone A/C. The passenger side sems to work fine, but the driver's side seems to blow warmer air all the time no matter what the setting. I was just wondering if there is a sensor in the cab that tells the A/C the inside temperature on each side so it can adjust the temp. If so, I think it is reading the temp. on the driver's side is screwed up. Any suggestions?
1987 GMC Suburban 1/2 ton 4x4 (Beater) 1998 GMC Suburban 2500 4x4 1972 Olds 442 Convertible 2006 GMC 2500 Duramax Crew Cab (Sold) 1972 Blazer 4x4 (Sold) |
Re: 2006 GMC Air-conditioning question?
I would guess the blend door actuator for the drivers side is not working correctly
