Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 04-30-2010, 09:25 PM   #1
71-C10
71-C10's Avatar
95 Blazer Vacuum line question
I have some dry rotted vacuum lines under the hood that I am replacing. There is a 7/32 line that runs from a check valve close to the vacuum reservoir, across the top of the power brake booster, then somewhere behind the engine (4.3). The hose has already split and came off on the engine end, so I can't trace it. There is not enough room to see behind the engine where the hose connects. Where does this hose go? Any help will be appreciated.
Eddie
71-C10 is offline   Reply With Quote
Old 05-01-2010, 06:33 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: 95 Blazer Vacuum line question
it goes to a "T" behind the intake to the pass. side of the dizzy.
on end of the T goes to the vac. switch on the transfer case, another to your hose, and lastly it feeds from a metal nipple on the rear of the upper intake about 1.5" from the T.
if you have further issues with vacuum hoses let us know. I have a mental picture engraved so deeply it will never wear off.
68C15 is offline   Reply With Quote
Old 05-01-2010, 07:08 AM   #3
71-C10
71-C10's Avatar
68C15, thank you for your reply. From your information, can I assume that I will see my target the best looking on the passenger side? There's so much crammed between the back of the engine and the firewall, it's almost impossible to see anything.
Eddie
Old 05-02-2010, 06:50 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
the only way to see it is to lay on top of the engine. it is easy to find by feel though
