05-05-2010, 08:00 PM | #1 |
To Blast or???
Are you guys blasting the cabs or hand sanding? Just need help getting rust off my cab.
anyone know what it cost to blast the cab? |
05-05-2010, 08:26 PM | #2 |
Re: To Blast or???
Kabwe on his 55-58 build thread just posted to me a source for blasting that charges $250 to blast his cab and said everyone else quoted him $400. Now $250 is better of course, but either price strikes me as pretty reasonable compared to the EFFORT and MESS that manual sanding would be. I'm going to have the components of my '46 bed blasted using his source, then later the hood and front fenders and I'll decide on the cab itself later.
05-05-2010, 08:41 PM | #3 |
Insane In The Membrane
Re: To Blast or???
I don't recommend sand blasting on these trucks. The sand gets caught up in between the roof panels, cowl panels, etc. Then it collects moisture and rots from the inside out.
I do however recommend soda blasting, it's blasting with baking soda. Works just as well as blasting and doesn't warp the metal. If it does get stuck anywhere it dissolves.
Cameron Gunlock Project: ALTER-K-TION ('57 GMC Quad Cab) http://67-72chevytrucks.com/vboard/s...d.php?t=393750 |
05-05-2010, 08:45 PM | #4 |
Re: To Blast or???
I decided to go the sand blasting route and was glad I did. It wasn't cheap as it cost me $1600 cdn for the entire truck.
When I bought the truck the fenders were already smoothed, sanded and in primer. I decided that since I was doing most everything I might as well do the fenders over just to know what truly lies beneath. Man what an eye opener that was. The end result was 3 new fenders. |
05-05-2010, 11:23 PM | #5 |
Re: To Blast or???
I blasted all mine myself... cost me about $500 in the end, and I built my own pressure blaster, rented the 90 cfm compressor and 11 bags of medium crushed glass. Absolutely no warpage and I sure ain't no pro.
A fine painting begins with a fresh canvas! Just my two bits, since I prefer to do everything myself... it's a pride thing. Cheers! Ted.
'51 Chevy Build - In the design stages Aut viam inveniam aut faciam - I will either find a way or make one. If you don't have time to do it right the first time, when will you... My new build - https://67-72chevytrucks.com/vboard/...70#post8958970 |
05-06-2010, 01:41 PM | #6 | |
Re: To Blast or???
As to the blasting, can we get more info about "making my own pressure blaster". I'd love to see how you did that. 4DSeven, You're right about a clean canvas. Your truck in pieces looks so clean - excellent! Not like working on a rusty old piece of crap like many of these trucks start out prior to painting. |
05-06-2010, 02:21 PM | #7 | |
Re: To Blast or???
I'm just one of these people that refuse to pay someone good money for something that I think that I can do myself... and besides... you learn something in the process and have new tools left over in the end! Not to hyjack a thread... but the pressure blaster started out as good clean 30 lb propane tank, purged and cleaned, with 2" nipple cut out and welded to the top, a handfull of 1/2" ball valves, some flexible line, a pressure regulator and relief valve and a pressure guage fitted. Then a long length of flexible brake hose with a deadman valve at the end. Mount the whole thing to a 2 wheel dolly with a leg out the front and you're good to go. (Would highly recommend spending the little bit to have it hydro'd for safety!). There's a pic of it in my build thread. Cheers and good luck, Ted.
05-06-2010, 10:16 PM | #8 |
Re: To Blast or???
If you take the cab to a blaster make sure that they do sheetmetal on a regular basis as some of the guys who normally blast heavy or farm equipment may be too heavy handed with the blaster and warp the panels. If you can find one that is tied in with a powder coater they may be more used to items that need a fine touch.
05-07-2010, 12:01 AM | #9 |
Hollister Road Co.
Re: To Blast or???
Phineas J. Whoopee was the mad scientist from the cartoon Tennesee Tuxedo
05-07-2010, 09:18 AM | #10 | |
Re: To Blast or???
I need one of those....... |
05-07-2010, 11:28 PM | #11 | |
Re: To Blast or???
We spent many, many hours trying to straighten out these problems on doors and hood and the back of the cab on TWO projects. Be careful who you chose, these cabs and sheet metal will WARP big time !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
05-08-2010, 01:56 PM | #12 |
Re: To Blast or???
my cab is going on the 21st to get blasted. this guy does p coating too and i have seen some of the stuff he has blasted came out nice no warping.i asked for a quote he said $60.00 an hour. that is a good price i think. he also said if it only takes an hour and a half it will be $70.00.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
05-12-2010, 11:07 AM | #13 |
Re: To Blast or???
I talked to guy out that dose plastic blasting he said it just takes off paint not rust an no damage to the metal what do you guys think of that.
1996 Dodge 3500 4x4 1977 F250 Camper specal 4x4 1956 Chevy 3100 truck |
05-12-2010, 11:35 AM | #14 |
Re: To Blast or???
I've heard all these warnings about warping sheet metal and I'm going to be asking a LOT of questions before I commit to someone. I've got Kabwe's referral to a guy and two other guys through people I trust too, so I should be able to find 1 of 3 that knows how to do sheet metal and will do it reasonably priced.
05-12-2010, 12:26 PM | #15 | |
Certified Car Nut
Re: To Blast or???
Dan here is an link to an article that was done on the place I recommended, read it you may like it. It was one of the reason I chose them because I don't know anybody that put time, love and money in the cars like the lowrider crowd.lol The chrome alone could buy a house in some states.lol http://www.lowridermagazine.com/tech...ing/index.html Last edited by Kabwe; 07-30-2010 at 12:55 PM. |
05-12-2010, 01:24 PM | #16 |
Re: To Blast or???
Kabwe,
Thanks so much for the link. Unfortunatley I can't access it from my work computer but I'll defintiely look forward to reading it tonight. If the place primarily does cars then I would agree they are VERY careful not to warp anything or word would get out and they'd lose business fast. |
