Old 03-14-2001, 08:11 PM   #1
Kracked
Question Screwed up wireing
Today I turned on winsheild wipers in my 82 and all my gauges went haywire, and the wipers did not work.
Got home and started to work on it to figure it out. Turned on the headlights with key off and all the gauges went wild again.
Any suggestions? Where should I start? I pretty sure its a ground problem, but don't know where to start.
68 C/30 Pickup
72 C/20 Suburban
72 GMC Suburban 4x4
Kracked is offline   Reply With Quote
Old 03-15-2001, 07:52 PM   #2
DBLSPRT68
DBLSPRT68's Avatar
Question
TRY UNPLUGGING YOUR WINDSHEILD WIPER MOTOR. THAT'S WHERE IT STARTED RIGHT. MAYBE THE MOTOR SHORTED OUT AND WITH IT BEING GROUNDED, IT'S MESSING WITH OTHER STUFF.SEE IF THAT HELPED. NEXT CRAWL UP UNDER YOUR DASH AND LOOK OVER WIRES, COULD HAVE A POWER OR GROUND THAT'S RUBBED AND ARCING WITH OTHERS OR GROUNDING OUT.ALL I CAN SAY IS TAKE YOUR TIME AND FIGURE IT OUT. YOU COULD BURN YOUR TRUCK TO THE GROUND IF YOUR NOT CAREFULL. GET A FIRE EXTINGUISHER. DAVID
NEW TRUCK: 1982 3/4 LWB CHEVY 350-TH400-2WD W/89 SUBURBAN FRONT. TOYOTA CELICA DAILY DRIVER. PROJECT:1965 BEL AIR 2-DOOR.
MEMPHIS, TN
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
