05-10-2010, 12:09 AM | #1 |
4x4 sway bars
Anyone have a reccomendation for front and rear sway bars for my 72 3/4 ton 4x4? Does Addco still make them for this rig? Going to be hauling a camper and would like to run sway bars. Also interested in any suggestions for rear air bags.
'69 3/4 ton 427 CST Pickup '71 CST Blazer '72 GMC 3/4 4x4 |
05-10-2010, 05:40 AM | #2 |
Re: 4x4 sway bars
Hey Zeus,
If you have a look at my build thread, post 61 ish, you can see what I did. Thread here - http://67-72chevytrucks.com/vboard/s...=217490&page=3 May be some better (easier) options for you being LHD. If you run a stock front bar I would recommend quick disconnects from ORD. Let's it 'move' properly. I looked into the airbag assist deal (even added an additional cross member for bracing) but didn't end up putting the Firestone bags that I had got in because they limit travel sooo much. These - http://www.thecarlisuspension.com/do...elairbags.html are the only bags I have found on the market that wouldn't limit the travel. Bags only were from memory about $200 each.
1972 K2500 Long Box 400/350 |
05-10-2010, 06:53 AM | #3 |
Re: 4x4 sway bars
stock 70's style front sway bar will work but you need to modify the crossmember or pull the original with the sway bar.
not sure on the rear...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
05-10-2010, 09:40 AM | #4 |
20' Daredevil (Ret)
Re: 4x4 sway bars
fwiw, I once called JC Whitney to ask if their sway bars were made by either Addco or Hellwig. The guy said they weren't allowed to say what the brand was, but I would recognize it. Turned out to be Addco -- so if they show a listing for your truck, it should be a good brand.
05-11-2010, 10:25 PM | #5 |
Re: 4x4 sway bars
Thanks for the info guys. Gives me a few directions to try.
08-19-2010, 01:55 AM | #6 |
Re: 4x4 sway bars
I have added a sway bar to my 72 K20 by taking all of the sway bar pieces off a 4x4 square body. That includes the u bolt plates, the sway bar, and the front crossmember (which has all of the goodies on it for the sway bar to mount to). Almost every time new bushings need to be ordered as the used bushings are usually worn out. Plus they are easy to replace while everything is apart. On my truck I removed the 72 cross member first. Then I installed the bar to the u bolt plate. Next I loosely fit the square body cross member into the frame. Then I attached the sway bar to the cross member. I made sure it was straight and drilled some holes in the frame, bolted it up and its ready to go. It ended up being approx. 3 1/4 inches from the front cross member bolt to the rear rivet on the leaf spring hanger. Measured center to center.
08-19-2010, 11:21 AM | #7 |
Re: 4x4 sway bars
Thanks Ray. Cant wait to get the sway bar. Yours look so nice I should just drive the truck to your place and let you install it. ROAD TRIP.
ROD 1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C. 1971 C20 Camper Special. 350/350. SOLD 2002 Chevy Tahoe LT |
08-19-2010, 03:21 PM | #8 |
Re: 4x4 sway bars
Better yet. I could deliver it up to your house, help you install it, and then head on over to the trailer races that they do every year in WI.
08-19-2010, 05:51 PM | #9 |
Re: 4x4 sway bars
If you are talking about these races, they will be starting this fall. Come on over. We only live a few miles from the race track.
ROD 1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C. 1971 C20 Camper Special. 350/350. SOLD 2002 Chevy Tahoe LT Last edited by Rodk65; 08-19-2010 at 05:52 PM. |
12-20-2010, 01:19 PM | #10 |
Re: 4x4 sway bars
To the top for Big Mac.
07-07-2013, 02:37 AM | #11 |
Re: 4x4 sway bars
ttt
07-10-2013, 11:12 PM | #12 |
Re: 4x4 sway bars
They had a rear i think as an option i found one at the junk yard i plan on picking up, there was one for sale on here and i also found it in my 85 service manual i like its design but ford has a design i like as well in their 9th generation trucks i believe...
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
04-21-2014, 11:06 AM | #13 |
Re: 4x4 sway bars
ttt
04-22-2014, 04:45 AM | #14 |
Re: 4x4 sway bars
Yeah the front is a must the rear was more of a option for years.Most i seen a rear swaybar on was 1 tons.
04-24-2014, 02:36 PM | #15 |
Re: 4x4 sway bars
Question: For a light truck, such as my K5 Blazer, a good set of Bilsteins 5125's should be sufficient for enhanced street handling. A sway bar would be overkill... right?
04-24-2014, 07:59 PM | #16 |
20' Daredevil (Ret)
Re: 4x4 sway bars
Wrong. Swaybars and shocks have completely different jobs. Suspensions are complex, but the basics boil down to this: Shocks help control jounce & rebound so the vehicle doesn't go boing boing boing down the road after every bump. Swaybars help keep the vehicle flatter (less leaning) while cornering. If you're satisfied with your rig's cornering and don't think it leans too much, forget about the swaybar. But if you'd like it to lean less and handle better, try a front swaybar. For further improvements, add a rear swaybar. Just don't add a rear bar without a front bar. Handling can get spooky.
10-28-2014, 12:41 AM | #17 |
Re: 4x4 sway bars
ttt
10-28-2014, 01:11 PM | #18 |
Re: 4x4 sway bars
Did you ever figure out a sway bar option? I would like to add a front and rear to my 72 4x4 suburban also.
10-28-2014, 02:38 PM | #19 | |
20' Daredevil (Ret)
Re: 4x4 sway bars
11-28-2014, 11:55 PM | #20 |
1972 K20
Re: 4x4 sway bars
I suggest using a73-78 front bar and crossmember. They show up in the classifieds a lot. I also found a burb rear bar again in the classifieds that works really well with a cab over camper. I have a 2 in lift and the truck has no noticeable body roll. I also put air bags on but I don't think I needed them. The max pressure I run is 10 psi. The best mod for handling by far!
12-01-2014, 10:07 PM | #21 |
Re: 4x4 sway bars
Its all in the Geometry. The factory cross members from the 73 up that the front sway bars attach to are not "exact" 90 degree / perp when installed in the 72 frame rails. Sliding the cross member in the rails, you have to use a wedge washer to mate it up tight. I used the 79 Blazer-K5 front sway and cross member supports with a modified steel cross support.
72 K10 |
01-15-2015, 12:24 AM | #22 |
Re: 4x4 sway bars
I am putting a sway bar from a mid 70's truck in my 72 blazer 4x4 but unfortunately I have the 2.75 inch axle tube dana 44 and the spring plates came off a 3 inch tube. Does anyone make a spring plate with 2.75" ubolt holes and the sway bar mounting holes?
I'm not saying let's go and kill all the stupid people. I'm just saying let's take off all the warning labels and let the problem sort itself out. |
02-07-2015, 10:20 PM | #23 | |
Re: 4x4 sway bars
Eric |
02-16-2015, 02:55 AM | #24 | |
Re: 4x4 sway bars
http://www.ruffstuffspecialties.com/...25GM-UPLT.html
Real trucks have a clutch. Please inform automakers. 1972 GMC, K25, 383 stroker, SM465, NP205, Eaton HO-72 |
02-16-2015, 12:18 PM | #25 |
Re: 4x4 sway bars
I believe a lot of the sway bar set ups came on 1ton trucks witch had Dana 60's under them. I had the same issue but found a pair that were 2.75. I bet a machine shop could drill and tap a set that didn't have a sway bar from the factory !
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
