Old 03-18-2001, 09:27 PM   #1
gearhead dave
Cool bed removal
i am in the process of removing my bed from my 76 crew cab, and was wondering what kind of things that i need to watch out for? How is the wiring routed thru the bed? How heavy is it?
thanks
dave
1976 Crew Cab Dually (under construction)
1972 Suburban
1955 Pro Street Chevy
1985 S-10 Blazer (daily driver)
V W Sandrail
Located in Horn Lake, MS that's just 4 miles south of Memphis TN
www.classictruckshop.com/clubs/earlyburbs/members/gallery2/223/display.htm
1972 Suburban
V W Sandrail
Former engine builder for Racing Head Service
Performance Engines in Memphis TN. over 1,600 plus engines built by little ole me!!
GOD BLESS THE BRAVEST OF THE BRAVE...THE NEW YORK CITY FIRE FIGHTERS!!
gearhead dave is offline   Reply With Quote
Old 03-19-2001, 05:35 AM   #2
bigblue
Post
it's a pretty simple job to remove the bed
the wiring should be ran down the inside of the driver's side frame rail and should have little rubber connectors at various intervals that allow the wiring to pass thru the frame cross members, you should look for the last connctor near the rear of the truck (should be just a bit behind the rear bumper inside the frame rail) just before the harness runs into the tailights and such ,unplugging it here should dissconnect all the wiring from the bed
as far as weight i could not say but i do know they are heavy but 2 people should be able to lift it (3 or 4 is nicer though)
there are 6 or 8 bolts holding the bed on (nut is inside the frame rails) but beware as they are the kind with the little sqaure just below the head to keep the bolt from turning but on my 70 the square holes in the bed were rounded out and i had to drill out over half the bolts (not to hard just a little time consuming)
hope this helps
if you are unclear on the wiring and had a couple of days to spare i could snap some pictures of my 70 and 74 and email them to you (sorry no digital cam or i would have put them up now)
70 GMC 1/2 ton 350/350auto 2wd lwb (bigblue)
74 GMC 1/2 ton 350/350auto 2wd lwd
93 Chevy k1500 z71 ext cab 350/auto swb
67 Plymouth fury 2dr 318/auto
bigblue is offline   Reply With Quote
Old 03-19-2001, 11:04 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Post
Don't forget to disconnect the fuel tank lines too. While you have the bed off, go down to the local carwash and give the truck a good cleaning. This would also be a good time spray paint the fram with some black paint. Why not lower the truck too. A shackel and hanger installation are easier with the bed off the truck.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
