Old 05-13-2010, 03:05 PM   #1
burntove
'59 pache
burntove's Avatar
Help on '59 back glass install
Anyone know if the rubber lock strip goes on the inside of the cab or the outside? Also I saw a old service manual that said to install the gasket on the cab first and then work the glass into it, does this sound right?
burntove is offline   Reply With Quote
Old 05-13-2010, 03:40 PM   #2
blackdiesel
blackdiesel's Avatar
Re: Help on '59 back glass install
outside, and yes put it on the cab first.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 05-13-2010, 05:45 PM   #3
OrrieG
OrrieG's Avatar
I am guessing you would use a rope just like the windshield, put the bottom in first then use the rope to roll the lip around the glass.
OrrieG is offline   Reply With Quote
Old 05-13-2010, 06:35 PM   #4
blackdiesel
You can use a soapy rope to pull the glass in, but with out the lock strip in the rubber there is alot of room to install the glass in it.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 05-13-2010, 08:44 PM   #5
mylow53
mylow53's Avatar
i had a guy do it since i tore thru 2 of the rubber gaskets. definatly worth the money and lower frustration. i think the rubber is pretty unforgiving when you pull the rope. mine kept cutting in to the rubber... you might try steel rubber if yours fails
good luck
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
