![]() Join Date: Oct 2008
Seat fitment
Will these seats (out of 86 crew) bolt in on a 73 Jimmy? I'm mostly interested in the center seat. Could I just bolt it between the stock 73 buckets? Did Suburbans come with a similar center seat and would it be a better fit?
Re: Seat fitment
those seats are aftermarket seats....i dunno if the center seat will fit between......you could just measure and see.....but i dont think it will.....it looks too wide...but if they were bolted into a crew cab that should fit in the 73......i dont know if the bolt holes will line up but that's a simple fix...hope this helps
if my manliness is determined by my wallet....i must be a 7 year old little girl... rule number 1...if it dont fit...use a bigger hammer.....if it still dont fit....you've got an electrical problem |
Re: Seat fitment
i've used a set of aftermarket seats in my blazer. the floor brackets had to be modified to mount on a flat surface and the bolt holes won't match but other than that the sizes are the some.
i think the center hump on a 86 crew may be higher than the 73 jimmy also but cant be sure Last edited by tobiahr; 05-15-2010 at 11:46 AM. |
Re: Seat fitment
So, was there ever a factory center seat option for this generation (73-91) of blazer/subs? If anyone has pics lets see it.
Re: Seat fitment
there was no factory center seat option for this generation of burbs or blazers. the closest is the bench front on the burbs
78K & 79C Jimmys
Re: Seat fitment
mine were custom very close to what you are showing,the center jump seat (and the rest were) bolted with 1/2 inch bolts threw the floor,the bases all custom welded/bent to fit the burb floor,truck was RPO'd with only a (factory)front bench
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Slots go on anything!
Re: Seat fitment
The pickups and Suburbans both have the large humps in hte floor, while the Blazer has a flat floor. You could probably retrofit seats from 88-up a lot easier as they all had flat floors.
1974 Jimmy- 5.3/4L80e/NP241 |
Re: Seat fitment
