Old 05-14-2010, 11:07 PM   #1
joe231
joe231's Avatar
I need some photographic help
As some of you might know, I'm retro-fitting the entire harness and TBI set-up into my crew cab from a '89 'burb. I am trying to figure out all the routing and some of the wiring. The PO of the 'burb cut the ends off of some of the wiring, including ground lugs and the alternator plug and eyelet. I could use some under hood shots of the wire routing (89-91 Blazer, 'burb or crew) as well as the wires running to the alternator and the power junction block located on the firewall above the brake booster.
thanks in advance guys (and/or gals )
CHEVY ONLY
Old 05-15-2010, 11:28 AM   #2
justpball
justpball's Avatar
Re: I need some photographic help
see if any of this helps, I have alot of extra stuff because of the airride but here are some pics
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 05-15-2010, 12:58 PM   #3
joe231
joe231's Avatar
Cool
thanks!
Where does the heavy wire in loom coming off of the back of the alternator go?
And what color are the 2 wires that plug into the alternator?
CHEVY ONLY
Old 05-15-2010, 01:50 PM   #4
justpball
justpball's Avatar
heavy gauge goes to the battery and the two small gauge are black and red with black stripe
87 Crew SWB
Build for the crew
90 burb 2wd
Old 05-15-2010, 02:27 PM   #5
joe231
joe231's Avatar
Cool
thanks!!!!
CHEVY ONLY
Old 05-15-2010, 07:10 PM   #6
joe231
joe231's Avatar
What year are the pics from?
CHEVY ONLY
Old 05-15-2010, 10:38 PM   #7
justpball
justpball's Avatar
1990 burb
87 Crew SWB
Build for the crew
90 burb 2wd
Old 05-16-2010, 12:12 PM   #8
joe231
joe231's Avatar
I was just wonder because your colors don't match anything I have or the diagrams i have.....
CHEVY ONLY
Old 05-16-2010, 12:41 PM   #9
Stitch
Location: Where I come from, it's cornbread and chicken...
my crewcab is an 87 and it had TBI in it...give me a few and I'll go take some pics of the harness for ya...it's still in the truck...
edit: went outside to the truck and the wires were cut to the alternator...also, there was one large red wire w/ ring terminal and one smaller wire with a two hole ring terminal on it going to the junction box...
in the first picture you can see those two wires on a harness I have from a burb...dont' know what year though...
also, the second picture is of the wires that are coming out of the burb harness where the alternator would have been...the wire colors are from left to right...blue, red, purple, black/yellow stripe, yellow...
hope this helps...
Stitch is offline   Reply With Quote
Old 05-16-2010, 01:20 PM   #10
joe231
joe231's Avatar
Thanks Chuck!
I hate all the cut happy people!!
CHEVY ONLY
Old 05-16-2010, 03:29 PM   #11
Stitch
did that help you any...I also need to know where these last wires goto...I know where the big gauge red wire goes of course, but the others I'm not too sure...
Old 05-18-2010, 11:58 AM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
duno if it helps but here is pics of 85/89 subs one of 89 more plus diagrams
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 05-18-2010, 12:02 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
does this help?
John
Old 05-22-2010, 11:12 PM   #14
joe231
joe231's Avatar
sorry guys, i've been up to my eyeballs trying to get my crew on the road....
the black and white is ground, the only larger purple I know of goes to the starter solenoid, the blue I'm not sure of, does it have a stripe?....and the last wire, is it white or tan? does it have a stripe?
Originally Posted by motornut View Post
does this help?
in the last pic can you tell me the colors of the wires going to the alternator?
those diagrams look nice, but I can't read them...
Justpball,
can you tell me what the wires go to that I highlighted in your pic?
Name:  6aafa732 highlighted.jpg
CHEVY ONLY
Old 05-24-2010, 01:41 PM   #15
justpball
justpball's Avatar
yea that wire goes to the back of the alt, it is the 2nd wire on the hot side.this one
87 Crew SWB
Build for the crew
90 burb 2wd
Old 05-24-2010, 10:27 PM   #16
joe231
joe231's Avatar
Ok
cool
thanks!
I think I have it sorted out.
Chuck, I think I figured out where that blue wire goes..... ESC module to the knock sensor.
CHEVY ONLY
89-91 under hood wiring
