Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-18-2010, 04:05 PM   #1
drag_72
Ready to go fast!!
drag_72's Avatar
Make my truck hook!!
its got adjustable ladder bars, narrowed 9in(that doesnt matter) 4.11 gears, coil over shocks.
it just spins the 18.5's off like nothing. i dont think thats supposed to be right lol but if someone has ever had the same problem and has adjusted something to fix it or if someone knows a little bit of tuneing advice for me that'd be great! thanks
454 block .30 forged aluminum pistons
steel crank
valve job
Holley Strip Dominator intake
1030cfm holley carb, 250 plate shot
roller rockers Erson Solid cam split duration 307/310.
.575/.595 lift
milodon oil pan
fab. aluminum valve covers
4 bolt main splayed anodized caps
all studded
drag_72 is offline   Reply With Quote
Old 05-18-2010, 04:53 PM   #2
Ont67shortbox
Re: Make my truck hook!!
what air pressure are you running, is it a slick or DOT tire ?What is the size of the tire ?
Ont67shortbox is offline   Reply With Quote
Old 05-18-2010, 05:00 PM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Air pressure can effect it a lot like mentioned. How much pinion angle are you running?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-18-2010, 07:02 PM   #4
drag_72
Ready to go fast!!
drag_72's Avatar
DOT Mickey thompsons. they are 18.5's. not sure on the pinion angle. i will check tomorrow. and when i get on it hard a in a higher gear the a** end tends to shimmy back and forth. so im thinkin the wheelbase is jacked off on it?
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 05-18-2010, 07:35 PM   #5
Super73
Super73's Avatar
How high off the ground is the front hole of the ladder bar (middle of the bolt)?
Can it go up/down? If so, how far each direction?
What spring is in the front? (Would like to know rate and length if possible)
What spring is in the rear? (Would like to know rate and length if possible)
How about shocks both front and rear?
Is this traction issue on the street, at the track, both?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-18-2010, 09:16 PM   #6
midevil1
ShortBus KingPin
midevil1's Avatar
those tires suck. -2 on the pinion angle for a street vehicle is good. you mean, shimmy side to side? I'm not sure about a jacked off wheelbase, but it sounds fun....
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE)
2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE)
2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE)
midevil1 is offline   Reply With Quote
Old 05-18-2010, 10:03 PM   #7
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Isn't that a street racing term?
LOL....I'm sorry guy, I just couldn't resist! Just having fun with you.
Seriously..on those tires, You say they are "dot" tires but all street tires are going to be DOT approved. I clicked on your profile and it sure looks like you are running the M/T S/R pro street radials. Is that what they are?
I know I'm running the standard sportsman and they spin for miles. The sportsman "pro" are a little better because they are a wrinkle wall but not real good on the street.
Retard that timing about 15* and she'll probably hook real well. If you have the kind of power talked about in another thread, it might be hard to get them to hook unless you are in the wet box lighting them up.
prostreetC-10 is offline   Reply With Quote
Old 05-18-2010, 10:16 PM   #8
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Mickey T sportsmans are horrible, only they're good for is lookin good.
I know a set of Hoosier 31x18.5 pro street radials hook decent at the track.
ProStreet68SB is offline   Reply With Quote
Old 05-18-2010, 10:27 PM   #9
Dieselwrencher
This is the same thing I have noticed. Mine don't hook on the street at all during a wide open run. On the strip they are pretty good unless I leave the line with a lot of boost.
Ryan
Old 05-19-2010, 03:27 PM   #10
drag_72
Ready to go fast!!
drag_72's Avatar
come on now prostreet c10 lol im tryin to redeem myself and do it the right way lol
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 05-19-2010, 09:40 PM   #11
prostreetC-10
My Carbon Footprint
Hey....you took enough shots on that last thread that it's a good. Youz one of us again!! lol
Just wish my truck had that much power ya young whipper snapper.
Old 05-20-2010, 11:30 PM   #12
drag_72
Ready to go fast!!
drag_72's Avatar
what kinda power does ur truck make?
steel crank
valve job
.575/.595 lift
milodon oil pan
all studded
Old 05-21-2010, 01:21 AM   #13
prostreetC-10
My Carbon Footprint
I would guess a little over 400hp. It's got a lot of bark but not that much bite. It fools a lot of people. Granted......I know how to drive a 4 speed so I can put on a show. It's just a little comp 280/.520 lift. It breathes well and I don't want it any quicker. It's really just my cruising "shop truck".
The 67 fastback in my signature will be the real power. Will be a full roller 331 or 347 with AFR 185 outlaw heads. In a 2900 lbs car....she's gunna scoot!
Curious.....what heads are you running? Is that 1030 Holley a 4150 platform carb? Just curious where the cfm is coming from? I've got a couple of 1000 holley 4150s and they usually are not too good on the street due to the size of the venturis. That's a big hole to cover in the lower rpms.
Old 05-21-2010, 08:08 AM   #14
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I have to agree my sad sack 283 auto truck will fry the M/T's ....the 70's from wally world had more traction....can't imagine what going to happen with te Caddy??? But I'm sure I'm going to have issues....time to start thinking about moving some weight back....but the only thing left under the hood is the battery??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-25-2010, 01:26 AM   #15
red rumbler
red rumbler's Avatar
make you a$$ end real soft and make the front not too stiff but stiff and you should have a better hook up with weight transfer. you want it to squat and go. and you said you just got the ladder bars, itll take some patients and playing around to finally find a setup you like
red rumbler is offline   Reply With Quote
Old 05-25-2010, 07:50 AM   #16
Hottrucks
Hottrucks's Avatar
I don't understand the use of Ladder bars with our trailing arm suspention?? are you saying that the trailing arms will wrap up then unload like a spring??
Old 05-25-2010, 09:11 AM   #17
prostreetC-10
My Carbon Footprint
I'd be interested to know if that long piece of metal has any flex under a hard load. When I think of ladder bars, all I can think of is the 66-67 Chevelles that everyone had them on back in the day. Funny too because those Chevelles technically had a trianglulated 4 link.
Old 05-25-2010, 04:36 PM   #18
red rumbler
the ladder bar keeps the axel from wheel hop ( axle wrap ) and with thed ladder bar alot of people put coilovers or adjustable rear shocks instead of the leaf springs so the weight transfer is greater and puts more weight on the rear end ( squatting ). but now there are slider kits out there for the leafs so you just take or add leafs until you have the setup you like and the axel slides up and down the leafs for better hookup. without the sliders the leafs would bind with the ladderbars and the laderbars would be almost useless. if im wrong can someone correct me? but im almost sure thats the whole concept. im not sure about the flex though.. it makes sence that they would but i wouldnt imagine they would enough to make a difference
Old 05-25-2010, 04:37 PM   #19
red rumbler
softer the rear spring the more it will squat so coilovers are probs the best
Old 05-25-2010, 09:46 PM   #20
Hottrucks
Hottrucks's Avatar
so we agree ladder bars on a trailing arm suspention is useless
Old 05-25-2010, 10:06 PM   #21
Dieselwrencher
If you look at these chevelles, gto's, oldmobiles, and buicks, they use a type of traction devise in a shape of a c that goes on top of the rear axle. They work pretty well.
Ryan
Old 05-26-2010, 12:37 AM   #22
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
too bad they dont make the et streets in a bigger tire
they hook up like a mofo
id almost bet the et street radial is the hardest hooking dot tire you can buy
the widest radial they have is a 13.5 but the et street drag comes in a 16
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 05-26-2010, 01:22 AM   #23
Super73
Super73's Avatar
I'm sorry but I disagree 50%..
If your rear suspension has < 100% antisquat yes, ANY spring will squat. How much depends on your antisquat percentage, spring rate, shock adjustment and how far your front raises..
If your rear suspension has exactly 100% antisquat, your rear will not squat nor seperate if your fron suspension stays constant. However, this most likely will never happen. As your front raises, your center of gravity then does the same inducing < 100% antisquat, so again you will squat the rear.
Here is the problem with what you are saying.
If your rear suspension has > 100% antisquat, under load you will now get seperation (axle goes down in to the ground and the body moves up in the air). It doesn't matter if you have 50lb rear springs or 250lb rear springs.
This is why I asked all the questions I did in my first response on this thread. With out having a clear picture of what is really going on, it's going to be hard to help.
Old 05-26-2010, 03:32 AM   #24
team39763
For some reason, I always thought we needed the front end soft and loose and the back end firm and tight. Isn't excessive squat just wasted energy?
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 05-26-2010, 01:54 PM   #25
Super73
Super73's Avatar
Not always.. You could argue excessive front travle is wasted energy too.
I believe having a vehicle set up as loose as needed (with out being too loose) to make work is the best. The way to do this in my opinion is with light long springs in both locations, using a good adjustable shock. Knowing how to adjust rear suspension for squat/antisquat under varying track conditions and what effects that has on front suspension. Understanding when to loosen up the front vs the back.
Again, squat is a characteristic of your instant center of gravity in relationship to your center of gravity. If your instant center of gravity line passes above your center of gravity height above the front axle, you are going to induce antisquat no matter what spring you have in the rear (just might not raise as much). If your ICG is bellow your CG, you are going to induce squat, no matter what spring you have in there (just might not squat as much).
The higher the + antisquat number is, the more sepperation your going to create and the more it will force the rear tires in to the ground.
The lower the antisquat number the more squat your going to create and the more energy you will loose in the suspension.
If your trying to make something hook in the dirt, then yes put a ton of squat in it with a very light long spring in the rear and your shock in the loosest setting. Also put a very light long spring in the front and set your shock to the loosest setting. You will have a ton of weight xfer and not hit the rear tires as hard.
If you want it to work on a good hooking track, react fast on the hit (not have to leave on the 1st yellow) then put some antisquat in that thing and loosen the front only to where you need it. If the track starts going away, loosen up the front some more. If it's still going away, lower your ICG to get some squat in it.
