Old 05-24-2010, 11:39 PM   #1
bucannon
Salty Sailor
bucannon's Avatar
Exclamation parking light is going crazy!!!
okay so on my truck when the headlights are on the passenger side parking light does not work, but if i turn on the right blinker it will blink on!
what is the problem?????
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 05-24-2010, 11:49 PM   #2
bucannon
Salty Sailor
bucannon's Avatar
Re: parking light is going crazy!!!
Savannah, Georgia
Old 05-24-2010, 11:51 PM   #3
Manbearpig
Manbearpig's Avatar
Pull the bulb out and try cleaning the contacts
1972 GMC C10
Manbearpig is offline   Reply With Quote
Old 05-24-2010, 11:53 PM   #4
bucannon
Salty Sailor
bucannon's Avatar
Cool Re: parking light is going crazy!!!
been there done that
Savannah, Georgia
Old 05-25-2010, 12:11 AM   #5
Manbearpig
Manbearpig's Avatar
Try doing the other one too lol
1972 GMC C10
Old 05-25-2010, 12:28 AM   #6
Stepsideride
try changeing the bulb...one filament may be broken.
Stepsideride is offline   Reply With Quote
Old 05-25-2010, 12:31 AM   #7
bucannon
Salty Sailor
bucannon's Avatar
i have also tried replaing the bulb, still unsucessfull
Savannah, Georgia
Old 05-25-2010, 07:44 AM   #8
68longhorn
68longhorn's Avatar
You check for voltage with the parking lights on?
68longhorn is offline   Reply With Quote
Old 05-25-2010, 07:54 AM   #9
xrcr
I may be wrong but your signal and your marker should be 2 seperate wires. Sounds like signal works, marker don't. Broke wire? Broke wire going to ground? Bad contact at light assembly? Good Luck, I hate electrical problems.....
xrcr is offline   Reply With Quote
Old 05-25-2010, 10:21 AM   #10
bucannon
Salty Sailor
bucannon's Avatar
okay i will double check the wiring
Savannah, Georgia
Old 05-25-2010, 07:22 PM   #11
LONGHAIR
Many electrical problems end up being ground related. Check your grounds.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-26-2010, 02:35 AM   #12
bucannon
Salty Sailor
bucannon's Avatar
the ground is the same as the headlight ground and i cleaned it up.
still nothing.......
come on guys what else could be causing my problem??????
Savannah, Georgia
Old 05-26-2010, 11:28 PM   #13
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Does your green turn signal indicator on your dash stay on.. or flicker when you go down the road.. without the signals being on?
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 05-29-2010, 05:30 PM   #14
bucannon
Salty Sailor
bucannon's Avatar
yea the green signal on the dash stays lit until i turn on the blinker then it will blink
Savannah, Georgia
Old 05-29-2010, 06:26 PM   #15
Stepsideride
Is that at night with the Park lights headlights on?
If so you have a wire crossing somewhere.
Old 05-30-2010, 12:13 AM   #16
CaliDude76
CaliDude76's Avatar
OK.. mine did the same thing... what happens is that somewhere in your electrical loom there's a short.. or wires touching... which causes your green signal light on your dash to turn on.. though it shouldn't when you don't use the turn signals. The problem with mine was the wires that plugged into the parking lights was loose.. not meaning the socket that plugged in behind the light was loose.. but inside the connections.. try wiggling the wiring loom from the firewall.. all the way to the lights themselves.. maybe even disconnect it from he firewall connection.. and re-connecting it....
CaliDude76
Old 05-30-2010, 02:46 PM   #17
CaliDude76
CaliDude76's Avatar
Ok. I grabbed some pix so you can have a better idea, I have the same set-up.... The little black pig-tail on the top is what I was having problems with.. I wiggled that one.. and the light came back on.. it was real touchy... but it was the culprit... good luck
CaliDude76
bucannon
