Old 05-25-2010, 12:18 AM   #1
99 to Life
99 to Life's Avatar
Cab mount Hardware
I picked up some poly urethane body mounts for an
s-10, for my 51' However, I can't seem to find anywhere that
sells the bolts with the cupped washers and all that.
Does anyone know of a place? OR ideally any hardware
place that would sell something similar?
thanks
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-25-2010, 10:06 PM   #2
rhodog77
rhodog77's Avatar
Re: Cab mount Hardware
99,
I priced a complete set at my local chevy dealer. If I remember correctly, we have to buy them in a complete set (including the 2 sets for the radiator). You get all 12 bushing washers, 6 bolts, 6 nuts, 6 lock washers and 6 flat washers. It was pretty pricey. What happened to the stock ones off your s10. I sanded mine down and sprayed them with ruststop, and they look like new. I have a chevy dealership on my delivery route. I will check tomorrow and see if I can get a price for you. If worst comes to worst, Im sure your junkyard has a s10 lying around. With an good battery power impact drill, I bet you could get a set off an s10 is less than 20 minutes, just a thought.
brian
"Get Busy Living or Get Busy Dying"
1970 P10 Stepvan
rhodog77 is offline   Reply With Quote
Old 05-25-2010, 10:26 PM   #3
britnjc
britnjc's Avatar
LMC Truck is where i got mine
britnjc is offline   Reply With Quote
Old 05-26-2010, 11:28 AM   #4
99 to Life
99 to Life's Avatar
thanks for the response
Well the frame I got, obviously didn't have mounts because there
was no cab. I do have another one with a cab, I was planning on
taking them off, they have to come off at some point.
But I just wanted to save some time by buying them for now.
I really just want the retainers, the bolts and washers I wanna get
grade 8 at like tractor supply or something.
I think I will snag the retainers from lmc.
thanks guys
Old 04-12-2012, 11:30 PM   #5
yutrock
yutrock is offline   Reply With Quote
cab mount hardware
