Old 04-23-2001, 02:25 PM   #1
CoryM
Post Signals don't signal.
Hi, My 78s turn signals don't work. But the emergency flashers do. I am guessing it will be the turn signal switch. Is there anything else that might cause it to do this?
I'm pretty sure it has to be the switch but any input would be appretiated. Thanks. CoryM.
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070/
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
Old 04-24-2001, 01:48 PM   #2
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Post
Which ones dont work? All? If all turn signals quit at the same time but the flashers still work, I work look for a loose power wire to the turn signal assenbly first.
Toms River NJ
71 custom 20 - 307 3onthetree-bone stock
56 working Street rod (under construction)
92 Olds 98 land yhat..(wifes)
20 ft. long hole in water in which i throw my money
The number one cause of computer problems is computer solutions.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 04-24-2001, 03:48 PM   #3
CoryM
Post
Thanks Denny, It was the power wire going to the switch. BTW whoever designed the steering column on these trucks should be shot. Kinda sucks to remove the snap ring that holds the "lockplate" on Happy trucking CoryM
