Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 05-31-2010, 10:06 PM   #1
xragex3191
1986 chevy swb 4x4
I started my first chevy truck build a few months ago and figured i would share my progress. It started out as a 1986 chevy swb with a 350/350/203 combination in it which is whats in it now just a different tranny and t case since both the ones it came with were junk. This is what it looked like when i got it.
http://c1.ac-images.myspacecdn.com/i...aa72f7a538.jpg
since then i fixed all the rust on the cab, replaced tranny and transfer case, painted the frame rails, replaced brakes all the way around, removed the rusted up bed and replaced with a flat bed and rear tube bumper, and installed 3 inch body lift and a superlift 8inch suspension lift, along with many other odds and ends. this is what it looks like now tell me what you think.
Last edited by xragex3191; 05-31-2010 at 10:14 PM. Reason: pictures came up as links
xragex3191 is offline   Reply With Quote
Old 05-31-2010, 10:08 PM   #2
xragex3191
Re: 1986 chevy swb 4x4
http://c3.ac-images.myspacecdn.com/i...eb126e4e06.jpg
Just after the 3 inch body lift was installed.
Old 05-31-2010, 10:10 PM   #3
xragex3191
Old 06-02-2010, 11:37 PM   #4
84 400
Sb 400 club
84 400's Avatar
looks like a nice build. Wonder if it was a cab swap. The original drive train that it came with sounds like your standered 73-80 setup. What you running for axles? Little big for my taste but I really dig the flat bed. Keep up the good work!
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 06-03-2010, 05:05 AM   #5
xragex3191
The previous owner swapped the tranny and transfercase. You could tell because there wasnt a tight bolt anywhere and they tried to use the original drive shaft which would have been for the np208 so it wasnt even a slip style drive shaft. They just unbolted the yoke from the back of the 203 and jammed the drive shaft into the splines which actually are the same but was never gonna work. Anyway the good thing was when they got it together the tranny didnt work so it never moved that way. Everything they did was scarry like that, i only found one tight bell housing bolt lol. Oh the axles are just stock half ton axles both corp 10 bolts. Already looking for a set of 1 tons though. Im thinking 4.88 gears, lockers front and back, and a set of 39.5 inch iroks or 40 inch ground hawgs cant really decide which tires, tell me what you think.
