Old 06-07-2010, 11:49 PM   #1
bimaldo
Need help
I know these subjects have been covered many, many times and there are varied opinions out there. I will listen to all of them. I have searched for other posts of a similar topics that may have given me some clues where to start.
Here is the situation:
Just installed this new crate engine.
After talking to my transmission guy, I was convinced to upgrade to the 700r4, after all this truck is going to be for my daily commute - about 23 miles each way. ( At least for now ! )
After installation, the engine fired right up and ran great - without a transmissison attachted.
Using a tow dolly from Uhaul, delivered truck to transmission shop ( always get the insurance from Uhaul-just in case the tow dolly falls of the ball when towing, like mine did - that's another story)
When the transmission shop called and said it was ready, naturally I was excited to drive it. It ran like crap.
Transmission shop told me that they could not get WOT from accelerator pedal. Ok, so i fixed that. That made big difference.
Runs better.
I have also been tinkering with the timing. Right now it is set around 11°-12° BTDC.
(Vacuum advance disconnected from non-ported source on carb)
Runs even better.
Moved the linkage to the accelerator pump to the first hole on Edel 1406. Got rid of the hesitation.
Runs better still.
So here is my problem.
I am not pleased with the shifting form gear to gear.
1st gear only holds on for about 2-3 seconds before shifting into 2nd.
2nd gear hold a bit longer then into 3rd.
3rd gear holds forever before hitting the OD.
Once in the OD, the engine surges. It seems to bog then not then bog then not.
These shifting patterns are only when driving gently. When right foot gets heavy, I can wind the 2nd and 3rd gears out far, but OD still surges.
Questions:
Could the 1406 be running to rich in the OD? I plan on trying to change meter rods/jets to run leaner - maybe a 7 or even 12 and then try.
Could these problems be a result of an improperly set TV cable ?
It makes me wonder because transmision shop said they could not achieve WOT with the pedal, but probably set it by hand.
Any and all help welcome.
Bim
bimaldo is offline   Reply With Quote
Old 06-08-2010, 12:39 AM   #2
clinebarger
Re: Need help
Have you looked at these?
http://67-72chevytrucks.com/vboard/s...d.php?t=402683
http://67-72chevytrucks.com/vboard/s...d.php?t=402301
Was the TV cable reset after the WOT issue was solved? The transmission shop let it go like that? When you build a 700R4 you can not have a "I just fixed your transmission thats it" additude. Their responsible for TV set-up.
clinebarger is offline   Reply With Quote
Old 06-08-2010, 09:53 AM   #3
cableguy0
Re: Need help
Sounds like a tv cable issue to me. I would take it right back to the shop and make them readjust it. If they did the install they should have set it up properly. What rear gears do you have? what rpm are you turning when in od?
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-08-2010, 07:41 PM   #4
bimaldo
Re: Need help
Thanks for the ideas, guys.
I do not know what gears I have and have no tach.
I did readjust the accelerator pedal so that I now have WOT with the pedal, then set the TV cable according to the procedures found all over the interwebs.
Shifts much better now , however the OD gear takes alot to get to.
On another note, just found out heater core is leaking.
If it's not one thing, it's another, huh ?
At least it's fun fixing them.
bim
Old 06-09-2010, 11:06 AM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Need help
If the butt gears in your truck are already high, then the OD will make it like a dog. Was the truck at high RPM when driving at 60mph? Is that the reason for switching to the OD tranny?
I also agree on the TV cable being out of asdjustment.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-10-2010, 11:15 AM   #6
bimaldo
Re: Need help
Well its been a while since I posted this.
Set the TV cable properly and discovered that the issue with the surging was actually the TCC lock-up cycling.
Was able to adjust and working well now.
Thanks for all the input guys !!
Old 07-10-2010, 02:24 PM   #7
GASoline71
GASoline71's Avatar
Re: Need help
Kewl! Now you get to enjoy it!
Gary
1406, 700r4, surge
