Old 06-10-2010, 01:25 PM   #1
Mattman2010
Mattman2010's Avatar
80 Chevy k10 build
Hello guys, I am new here, I just picked up a 1980 K10 Pickup last Monday. This is my first project truck, and I am really looking forward to getting to work on this.
Pictures:
Grill is cracked, you can see it is held together with string, the right head light bezel is broken as well.
The Hood is bent, I know this is a problem with this style truck, how do I go about fixing it? It has been bent so many times that I will have to add some kind of support to keep it from bending.
It has a 250 engine/ 350 transmission/ 205 transfercase. The fuel pump is missing, and the PO said that the engine is making a clicking noise, but I plan on putting a 350 in it. It also has AC in it!
Does anybody know anything about this rear bumper? It sets in really far, and then the ends stick out farther. It has a frame in the bed for a hay lift, and im not sure if that has anything to do with why the bumper is like that.
This is where the hay lifts winch was mounted.
It seems to be in really good shape for being 30 years old, and being a farm truck. I dont know if I want to replace all of the dented areas on the truck or not. I plan on it being a Daily driver, and a mild offroader, so Im not sure if It is worth it to replace the bed and front fenders or not.
The Plan:
-Blue Body (Darker)
-All chrome, or non body colored things will be black
-350 Engine
-3/4 ton axles and springs
-New Stereo system
-Military Surplus Tires
Mattman2010 is offline   Reply With Quote
Old 06-10-2010, 01:56 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: 80 Chevy k10 build
Welcome to the forums!
I'd almost swear that is my Grandpas old farm hands truck, his name was Manny and he passed away about 12 years ago or so. I have no idea where his old truck went, but I'd really have to be convinced that wasn't his. Then again, there are a loooooooooot of those style out there, in that condition.
Looks like a good project for you, has some awesome potential though! I'll be watching.
RandyP is offline   Reply With Quote
Old 06-10-2010, 02:30 PM   #3
palposity
palposity's Avatar
Looking forward to seeing how this goes for you! Looks like you have a solid truck to start with.
I am betting that rear bumper is a custom job with the corners intended as steps.
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE - SOLD
DD--2008 Duramax CCSB
palposity is offline   Reply With Quote
Old 06-10-2010, 02:45 PM   #4
Rodms
Rodms's Avatar
The bumper is probably homade and in in the center so you could drop the gate down without kinking it in the middle ,If you swap to 350 I pretty sure you ac is on the drivers side and alt is on the passenger,I know alot about these trucks as I bought one in 1980 and still have it today,Dang I feel old now,I got a hood for it though off 79.
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 06-10-2010, 11:55 PM   #5
Mattman2010
Well, the guy that farms my parents land said that he has a 1980 3/4 ton, I am going to use it for parts. He says it was a high end truck at the time has power windows, power locks, ect.. I plan on stealing the 3/4 ton axles and springs (if they are 52" rears like mine) to make a Heavy Half ton.
Well the 250 engine has some bad news. It was missing the fuel pump, but I wanted to see if it would crank, because the PO said that it was making a clicking noise, and that it was getting really bad, so they parked it. Well after hooking a battery up to it, and trying to crank it, the engine was locked. So sense it was locked my dad and I started to look at it, and there was a hole in the oil pan from something flying through it. I planned on replacing the engine any way, it just means I have to get a new engine before I can drive it around, but that is what im going to get this parts truck for, it has a working 350 in it.
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Old 06-23-2010, 10:32 PM   #6
Mattman2010
Well I have not updated a lot, but I have done quite a bit lately. I have already removed the front clip, and pulled the engine and the 350 transmission out.
The 250 was blown, the connecting rod went through the block, and the cam shaft was broke, and a lot of metal floating around.
After I removed the front clip and engine/trans, I took off the bed and cab.
I spend two days going around the frame removing any rust/dirt i could. Tonight I final put a fresh coat of paint on the frame.
Should be picking up a 1980 K20 for parts this weekend. I plan on stealing the engine and axles out of it, and any sheet metal that is better than mine. I also plan on stealing the gauges out of it, instead of have the idiot lights in mine.
Build Thread
Build Thread
Thread
Old 06-24-2010, 07:57 AM   #7
palposity
palposity's Avatar
Nice job!!!
Old 06-24-2010, 08:10 AM   #8
RandyP
RandyP's Avatar
Looking good!
Old 06-24-2010, 09:33 AM   #9
Mattman2010
Thanks Guys, So far this has been a really fun project.
I have a few questions to ask though, How should I go about tipping the cab and bed over so I can paint the bottom of them black? Does the back glass on the cab need to be removed, or is there a way to set the truck on the back without removing the window? I just want to clean up the bottom sides of them, they are really muddy, and I'm sure the rust is starting, im just not sure how to go about setting them up and over to paint the bottoms.
Build Thread
Build Thread
Thread
Old 06-24-2010, 12:44 PM   #10
GMC91
Always trouble
GMC91's Avatar
On the cab, if you can slowly roll it over, have someone to put like a 4x4 at the bottom of the cab and right at the top, right above the back glass. Now, Im just guessing you could do it this way.
91 Silverado Regular cab, 2wd, swb-project truck
97 Silverado Extended cab, 2wd, swb-driver
GMC91 is offline   Reply With Quote
Old 06-24-2010, 12:49 PM   #11
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Originally Posted by Rodms View Post
The bumper is probably homade and in in the center so you could drop the gate down without kinking it in the middle ...
bumper is dealer installed item, we have several trucks with that bumper on -them, but most of them are 73-74s, although i think one of our later 77-80 has it as well.
Looks like a clean old 4x4, what ratio are your current axles?
overall clean looking truck, i likey
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 06-24-2010, 01:13 PM   #12
Mattman2010
I have thought about that, but I do not know if the cab will flex some causing the back window to break out.
What is the purpous of that bumper? The end parts that are sticking out have a hole on the inside almost like something was suppose to install on there? I want to find a new bumper, I'm just not sure what I want to run on it. I am not sure what the ration in the axles are. This is my first project truck, so I don't know how to do some things. I Guess what I need to do is jack one of the rear wheels up, and spin it and see how many times the drive shaft rotates to 1 rotation of the wheel?
Build Thread
Build Thread
Thread
Old 06-24-2010, 01:18 PM   #13
Walts_restoration
jack it up and rotate the pinion and watch and make sure both tires turn evenly at the same speed, and count how many turns of the pinion to one turn of the tire.
Old 06-24-2010, 02:19 PM   #14
Mattman2010
Alright, I will have to check that out this Sat. I hate working nights, and it being so hot out during the day, not much gets done!
Build Thread
Build Thread
Thread
Old 06-24-2010, 02:39 PM   #15
GMC91
Always trouble
GMC91's Avatar
The cab shouldnt flex with the doors and all still on it.
Old 06-24-2010, 02:45 PM   #16
Jonboy
Slots go on anything!
Are you planning on swapping out the power doors and all onto your truck? If so, it may be easier to swap out cabs and all, since yours is already torn down.
1974 Jimmy- 5.3/4L80e/NP241
Old 06-24-2010, 02:45 PM   #17
Mattman2010
Well I removed the doors already. So if I put the doors back on, and then set it on some blocks I should be able to clean and paint the bottom?
Build Thread
Build Thread
Thread
Old 06-24-2010, 02:49 PM   #18
GMC91
Always trouble
GMC91's Avatar
Well with the doors already off, I probally would put the doors back on just for this. But when I sold my old 86 K20, it was all in peices. And the way we moved it, we had to lay it down on its back and then rock it some to get it up on a wagon. And it had no doors on it and the back glass didnt break, neither did the front glass. We just didnt care if anything broke is why we moved it like that. But if you are un-sure and dont want to risk it, I would put the doors back on.
Old 06-27-2010, 07:04 PM   #19
Mattman2010
Well I got the 1980 K20 parts truck yesterday. My dad and I was able to get the 350 out of the truck. I think it has a dirty carb, because on the way to the shop from the PO house the truck would start to lose a bunch of power when you would accelerate it. I think the tanks also have some leaks, i had to refuel it 4 times to get the truck 4 miles from the PO house to the shop.
The PO said that the valve seals need replaced, and I also think the rear main seal needs replaced as well because their is oil all over the back of the engine, as well as the tranny. I didnt get any pictures yesterday, so I will get some pictures when the storms clear, and post them up!
Build Thread
Build Thread
Thread
Old 06-29-2010, 04:38 PM   #20
Mattman2010
Well I have not done anything sense I pulled the engine out, here are a few pictures.
Parts Truck
And the 350
Will be cleaning up the 350 tomorrow night, and start changing out the valve seals. Then I will be tearing it down more to change the main bearing seals, and look at the timing gear/chain. I plan on also changing out the Water pump, thermostat, hoses, spark plugs, and spark plug wires. Is there anything else I should change on the engine before I go about putting it back together? I will be putting headers on this (cousin is giving me some for free) and getting a custom dual exhaust on it in the end.
Matt
Build Thread
Build Thread
Thread
Old 06-30-2010, 10:47 PM   #21
Alex7191
Nice!! cant wait to see this truck done
Alex7191 is offline   Reply With Quote
Old 07-01-2010, 07:39 AM   #22
RandyP
RandyP's Avatar
Ohhh, a nice cattle guard on that parts truck, and cab lights. Well, I guess it depends on what the use will be for the truck, but I always loved trucks with cattle guards on them.
Old 07-01-2010, 10:42 AM   #23
Mattman2010
I plan on using that grill guard, and I have thought about using the cab lights, but I just don't know how I would install them, and I would hate to drill holes in my cab and have it leak.
I did a compression test on the 350, 7 of the cylinders are getting 180 PSI, one of them is getting 150 PSI. What am I suppose to be getting? Should I be worried about the 30 PSI gap between them?
Build Thread
Build Thread
Thread
Old 07-01-2010, 11:38 AM   #24
GMC91
Always trouble
GMC91's Avatar
Stock should be around 160 PSI.
Old 07-01-2010, 11:41 AM   #25
Mattman2010
So is that 180 a bad thing? If not, then should I be trying to figure out why that one cylinder will not go any higher than 150? Or should it be ok the way it is?
Build Thread
Build Thread
Thread
