06-19-2010, 07:21 PM | #1 |
The Red Menace
Hood won't pop up.
As long as I've owned this truck, I've had to release the latch with one hand and help the hood up with the other. The hood springs pull it up once I get it started and they hold it up fine. I'm wondering why it won't pop up when I release the latch. Any thoughts?
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
06-19-2010, 08:14 PM | #2 |
Re: Hood won't pop up.
Make sure the hood hinges are lubed and adjust the stops so that there is some pressure on the hood. Also, make sure the alignment pin is not binding.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
06-19-2010, 08:38 PM | #3 |
Between Trucks...
Weak springs. I replaced my hood hinges and springs and there was a big difference. Hood pops right up now.
Beat it to fit, Paint it to match... |
06-19-2010, 09:09 PM | #4 |
Back in the sticks
You could also try "tensioning" the springs by loosening the hinge bolts and pushing up the hood and re-tighten the bolts. Adds a little extra lift to the spring action.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
06-20-2010, 02:28 AM | #5 |
cleaning and lubrication makes moving parts work better
06-20-2010, 02:45 AM | #6 |
The Red Menace
Lubricating everything was the first thing I did. If I help the hood up to the first stop (where it's not fully latched, but not fully released) and then pull up on the latch again, it goes up the rest of the way with no trouble. It's just getting it from fully latched to "popped up" that that's the problem. I will try and adjust the stops and see if that helps. The alignment pin doesn't seem to be binding.
06-20-2010, 08:48 AM | #7 | ||
The hood springs have nothing to do with the initial opening of the hood, they just hold it open.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
06-20-2010, 09:07 AM | #8 |
i'd also try to loosen the latch and striker on both the core support and hood to see if there is a slight misalignment causing it to bind that little bit//could b off by 1/8inch or so and cause that slight hangup
06-20-2010, 11:28 AM | #9 |
The Older Generation
with cdowns on this. I think the locator pin on the hood is hanging up.
06-20-2010, 07:00 PM | #10 | |
Back in the sticks
I had the same issue with the 71 and got that advice on this board. Tried it, and guess what? It worked.
06-20-2010, 08:16 PM | #11 |
umm its normal mine does it too
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
06-20-2010, 08:20 PM | #12 | |
Facts are not opinions.
Someone told you wrong and maybe that adjustment fixed the bind of the latch pin by coinsidence. Adjusting the hinge mounting points has absolutely nothing to do with "Tensioning" the springs...which cannot be done anyway. If the springs are worn, they need to be replaced, but all they do is draw the hinges together. This holds the hood up, it does not "pop" it from the latched position. It they did the hood would raise by itself when you unlatched it.
06-20-2010, 09:00 PM | #13 |
Between Trucks...
When I unlatch my hood it raises by itself. New springs and hinges.
06-20-2010, 11:08 PM | #14 |
I've got the same problem with my 72. I do need to use more lubrication, that's been the least of my worries with it right now. But it is aggravating, I just recently replaced the hood with another one because the inner brace the hoodlatch mounts too was rusted out.
The problem is still there so still need to figure it out.
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) Last edited by Rob H.; 06-20-2010 at 11:09 PM. |
06-20-2010, 11:53 PM | #15 |
The Red Menace
I adjusted the pin and now the hood pops enough to get it open with no trouble. The hood does seem to vibrate or "oilcan" more when I'm idling than it did before, but that's another issue. Thanks guys!!!!
09-14-2021, 10:14 AM | #16 |
This is an old thread... but my 69 C10 had the same issue. My Fix was replacing (installing) the side hood bumpers I got from LMC. I bought my C10 3 months ago and the hood issue has been driving me nuts - LMC -30-1829
HOOD BUMPER SET-SIDE CHEVY GMC 67-72 $4.95 |
