Old 06-21-2010, 08:24 PM   #1
Chionos GMs
Chionos GMs's Avatar
Newbie needs truck help
Im a learning mechanic and Im lookin at a 76 K10 and it has a dieseling problem and I was wondering what would cause this and what can I do to correct the problem? also how hard it is to replace cab mounts? and lookin at this truck the springs in front where the shackle goes to the spring is rubbing the frame is this normal? I got alot of questions Thanks
Chionos GMs is offline   Reply With Quote
Old 06-21-2010, 08:47 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Newbie needs truck help
Dieseling is normally too high idle or a timing issue. On occasion, an electrical feed back when using electrical fans.
Cab mounts are easy to replace if you have a big enough floor jack.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 06-21-2010, 09:05 PM   #3
Chionos GMs
I have also heard it can be slack in the timing chain. is this possible? thanks
Old 06-21-2010, 09:18 PM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
http://www.73-87.com/7387garage/exte...b_bushings.htm
Good article so you see what you're up against on the cab mounts.
RandyP is offline   Reply With Quote
Old 06-21-2010, 09:45 PM   #5
Chionos GMs
Thanks. Im still considering the truck the biggest thing is the dieseling
Old 06-21-2010, 10:53 PM   #6
gchemist
gchemist's Avatar
GM used nylon gears on timing chains. When the nylon breaks, the timing chain is shot! It happend to my old 305. Timing chain failure finally did in the engine. I would start with checking the timing and tuning the carb. Use a vacuum gauge to tune it.
Old 06-21-2010, 11:03 PM   #7
benoit454
Chris
benoit454's Avatar
I don't see a timing chain causing it, either the idle is too high or the timing is wrong, usually it's the idle.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 06-21-2010, 11:08 PM   #8
Chionos GMs
Also I was driving it around and speedo cable must be broke and when I stopped and started the truck It was sounding like the battery was dead but I stopped and cranked the truck over and it started right up and the starter wasent cranking slow. Any ideas and how hard to replace cable?
Old 06-21-2010, 11:26 PM   #9
benoit454
Chris
benoit454's Avatar
huh? speedo cable being broke caused it to die or you shut it off? how the crap can it sound like a battery dead? if it's running? Need to clear things up a little better please in order for us to help you.
Chris
GIT R DONE!!!!!!
Old 06-22-2010, 12:43 AM   #10
Chionos GMs
I noticed the speedo wasent workin so Im guessin the speedo cable is broken. I pulled the truck over and shut it down and when I went to start it was acting like the battery was dieing because the starter was crankin slow. but when we got back to the sellers place and shut the truck down and he went and started it and the starter wasent actin sluggish and cranked over right away. Is it a starter problem? I hope I clarified the problem because I really dont know how to describe it.
Old 06-22-2010, 11:29 AM   #11
68longhorn
68longhorn's Avatar
Carbon buildup in the cylinders can also cause dieseling.
68longhorn is offline   Reply With Quote
Old 06-22-2010, 04:04 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
go back to nylon gears,in the timing chain,this is what i was told why my timing never seemed right ,in mine it cracked the gear pulled a strip of 4 or 5 teeth off but it was still attached,(couldn't see the crack till tension turned off chain, after removing timing cover,replaced with real steel ,drove the engine for a long time after
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-22-2010, 04:46 PM   #13
Chionos GMs
I decided against the truck sadly its a good deal if I had the extra cash to put into parts
Old 06-22-2010, 10:16 PM   #14
benoit454
Chris
benoit454's Avatar
As for slow cranking of the starter that can be casued by having the dist. too far advanced.
Chris
GIT R DONE!!!!!!
Old 06-22-2010, 10:34 PM   #15
Chionos GMs
Thanks for the help guys. Wish I had the cash for the work the truck needs. Oh well other fish in the sea I guess
My last name is Chiono pronounced key-ono even if my grammar teacher told me Ch dont make a K sound
1995 Ext. cab 350 4wd dd 260,*** miles
1986 1/2 ton swb 305 2wd (melted bearings) SOLD!!
1982 3/4 lwb 6.2 diesel 2wd
1962 Chevy 283 4 speed long step 2wd 2 OWNER GONE!!
Old 06-23-2010, 11:51 AM   #16
hotrod_991
hotrod_991's Avatar
when any of mine have dieseled its always been the timeing for me. usually too advanced but I also retune my carbs anytime i change timing so could have been that too i guess.
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
